Updated Sway Bar Bushing Design - JeepForum.com
post #1 of 9 Old 02-02-2016, 10:27 AM Thread Starter
DarthJeep
2005 WK
I'm looking to replace my '05 Wk front sway bar bushings and have realized that since 2005, there has been an update on the bushings and brackets. I believe that:
2005-2006 Wk's had the 30mm bushings with the 'flat' brackets.
2007-2010 Wk's had the updated 33mm bushings with the new center bead and updated brackets.
SRT8 and Xk's had their own 1.34" bushings or something....
My question is, if I buy the updated front sway bar bushings (33mm) and the new brackets, will this work? Even if I have the 30mm currently?
This site's wording makes me re-think http://www.justforjeeps.com/frswbarbu.html
Build Thread -
Black Wk Club 166
DarthJeep is offline
post #2 of 9 Old 02-02-2016, 11:32 AM
paroxysym
2007 WK
I run an SRT front swaybar on my WK- im running moog replacement bushings that came with their own brackets. just some food for thought since you need new bushings and brackets.
the 33mm bushings will not work on your 30mm- it will make your swaybar knock around and clunk. its pretty annoying
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #3 of 9 Old 02-02-2016, 11:47 AM Thread Starter
DarthJeep
2005 WK
I was trying to avoid buying an entirely new front sway bar. Are their any advantages to the SRT8 sway bar other than being 3mm thicker?
Build Thread -
Black Wk Club 166
post #4 of 9 Old 02-02-2016, 12:22 PM
paroxysym
2007 WK
why would you have to buy a whole new swaybar? if you get the moogs- trust me youll be happy. I replaced the bushings on my front swaybar and my rear addco with moog bushings and couldn't be happier.
I feel difference between the 30mm OEM WK bar and the SRT 33mm bar is minimal.
OEM+
post #5 of 9 Old 02-02-2016, 12:52 PM
JKM
2005 WK
Not sure where you got your info, but basically two sizes of sway bars on the WK. 1.29" and the 1.34" on the SRT. In 2006 they changed the bracket, which can you buy at a dealer and has the rib.
Part numbers for Moog
1.29" Sway Bar: MOOG K200159 (OEM#52089465AD, 52089465AE, 52089465AF)
1.34" Sway Bar: MOOG K200160 (OEM#52090155AG, 52090155AH)
JKM is offline
post #6 of 9 Old 02-02-2016, 12:59 PM Thread Starter
DarthJeep
2005 WK
The 2005 and some 2006 Wk's had a 30mm sway bar. So if I got the 33mm Moogs with the new brackets, they'd have a slight fitment issue, no?
Build Thread -
Black Wk Club 166
post #7 of 9 Old 02-02-2016, 05:53 PM
JKM
2005 WK
if you're sure you have the 30mm sway bar, then got those bushings. I have a 2005 and I updated my brackets and use the 33mm bushings, although I have a 33mm sway bar as far as I know.
I have never heard of the 30mm sway bar until your post and the link you posted. If you measured 30mm, then I would suggest you use those and stay with the old style brackets
JKM is offline
post #8 of 9 Old 02-03-2016, 12:01 AM
Kolak
Vendor
Kolak's Avatar
I do a lot of upgrades to the late brackets/bushings on the WK. Never seen a 30mm bar. I don't think the factory ever really used the smaller one.
PM me if you'd like pricing
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is online now
post #9 of 9 Old 02-03-2016, 04:31 AM
stephens039
2005 WK
My 2005 hemi came with a 33mm swaybar.
Khaki Club Member #85
stephens039 is offline
bushing fit , bushing replacement , bushings , sway bar , sway bar brackets
