Unusual CRD problem - Page 2 - JeepForum.com
post #16 of 18 Old 06-17-2013, 07:43 AM
gemiller
2008 WK
FYI, I get the smell many times that it goes into dpf regen and i'm running just fine. If you have the smell all the time thats certainly an issue, but remember the DPF will go into regen cycle on a pattern.
2008 WK Red Rock Crystal Pearl CRD || Lifted and stuff.
gemiller is offline
post #17 of 18 Old 06-17-2013, 09:13 PM
inhidin
2014 WK
If rough idle/loud idle - replace the crank position sensor. Had the same problem on mine - solved all issues.
inhidin is offline
post #18 of 18 Old 09-04-2013, 10:49 AM
miles85
2008 WK
Originally Posted by Jeeptheone View Post
merlinTec,
I have been told by DC in Aust that this is a one of a kind issue that no one else in the world has experienced to date. The wiring harness has been changed to the PCM, PCM x 2, Injectors twice and the 02 sensor twice just to let you know the effort thye have gone to.
Thanks for the advice.
JTO
Jeeptheone,
I also have a recurring cide the same as you. I have had the O2 sensor replaced. The P2A00 code comes back basically right away. You are not one in a million. Maybe two in a million.
miles85 is offline
Unusual sound from radiator area - pics and video included superarmen ZJ Grand Cherokee Forum 4 12-02-2008 04:04 PM
Unusual ZJ questions (keywords: daily driver, manual, sleeper). NuTone ZJ Grand Cherokee Forum 9 08-21-2007 01:40 PM
Unusual occurance with my WJ JPK ZJ Grand Cherokee Forum 10 03-27-2007 10:00 AM
Unusual problem with my 02 WJ Marine_Mike ZJ Grand Cherokee Forum 2 10-24-2006 10:45 PM
unusual sounds..... thejeeper02 ZJ Grand Cherokee Forum 1 08-28-2006 08:23 PM
