Undercarriage concern - JeepForum.com
post #1 of 13 Old 09-28-2013, 03:55 PM Thread Starter
coastalsurfer
2007 WK
So I've been looking for a Jeep for ages and I finally found what I thought is a gem and admittedly I think I was looking for so long and just got sick of looking and settled on this one but now I might be suffering buyers remorse I guess? I don't know.
It's a 2007 5.7l, has 73k miles and I got it for 14k, I tried to do right and checked to make sure everything worked and bought it cause it seemed right after doing some research. I checked to make sure everything was working properly but today I was throwing some stuff in the trunk and noticed some rust and now I feel like a ******* cause I didn't remember to check the undercarriage. I know. I'm an idiot. But I can't take it back now obviously.
I live in New England, and rust isn't uncommon but now I'm worried. Is this a lot of rust/in bad places? Is it a huge issue? I feel like such an idiot. I touched it and it doesn't seem to flake of at all. It's just a lot of discoloration. Is this common on this kind of Jeep? This is my first Jeep ever after wanting one for some time and now I finally found a Jeep with low mileage with everything I wanted and now I feel like it's going to rust out on me before I even get to enjoy it.
How can I fix it/how much would it cost to fix something like this?
I know I'm stupid and I'm sorry if this seems like a stupid question but I really appreciate any help.
coastalsurfer is offline
post #2 of 13 Old 09-28-2013, 04:04 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
This is not that big a deal at all. For one thing - that piece behind the spare is just a heat shield to insulate the spare from your exhaust. The rear tracbar, axle tubes, pumpkin, lower shock mounts, rear LCA mounts, and the rails can all be descaled with a wire brush or wire wheel and angle grinder - even good ol' fashioned 80 grit sand paper. Prime it, paint it; might not necessarily even need to prime it. Some flat black Rustoleum rattle can would work fine.
'07 HEMI with 73K on the ticker - $14grand - nice find IMO!
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #3 of 13 Old 09-28-2013, 04:41 PM
Zlartibartfast
2007 WK
yeah that's not so bad - try to get a good look at fuel tank and surrounding area - I read some folks found rust there that required them to repair or replace the tank
Zlartibartfast is offline
post #4 of 13 Old 09-29-2013, 06:36 AM
james_2k
2003 WJ
id mount the spare the other way around, might avoid some scratches on it?
mine was the opposite way to that.
james_2k is offline
post #5 of 13 Old 09-29-2013, 06:48 AM
AJeepZJ
2006 WK
yeah that's just some surface rust, man. If it were flaking, chipping, or worse (brittle)... Yeah that'd be a serious problem. After you sand those down, and repaint them. You might consider an undercarriage winter protection coat of some sort.
All Gear, No Skill.
AJeepZJ is offline
post #6 of 13 Old 09-29-2013, 09:19 AM
inhidin
2014 WK
Flip the spare over - but surface rust is no worse than what you see here in WI. Nothing to worry about. Bear in mind that it's almost a 7 year old daily driver.
inhidin is offline
post #7 of 13 Old 09-29-2013, 10:56 AM
LouC
2007 WK
I bet that a lot of WKs in snow areas have that same rust. What I'd do it remove the spare tire and then get some SEM rust converter. Wire brush any loose rust off, clean well with a solvent and then (use gloves and goggles as this stuff has phosphoric acid in it) brush on the rust converter. Let it dry a day and then prime and paint with Rustolium. You can use a brush on primer and paint, just get a nice coat of primer and paint on it.
Believe it or not my ZJ has hardly any rust but where I did fix it this same way is in the bottom edge of hatch. I put that stuff on like 5 years ago and the rust never came back.
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is online now
post #8 of 13 Old 09-29-2013, 11:50 AM
EthanC23
2005 WK
Wanna trade? That's nothing. You should have seen when I bought my jeep over here in Manitoba CANADA. Now that was surface rust. Like everyone else says, it's an easy "fix". Drive it up ramps, get on a creeper with a wirewheel and drill and go to town. I don't know what the climate is like where you are that well, but here it's winter 7 months out of the year, so I skipped the painting step and just wire cleaned everything and sprayed undercoating. I think undercoating is a better bang for your buck. 6 cans of it and the entire undercarriage will be done and last quite a few harsh winters. At $10 a can (Canadian currency atleast), you can't go wrong with undercoating.
EthanC23 is offline
post #9 of 13 Old 09-29-2013, 12:03 PM
LouC
2007 WK
Rust is a chemical reaction, O2 trying to combine with FE (iron) to make iron oxide (rust) FeO2.
You must neutralize any rust because the O2 in the air will get to it and start it all over again.
Wire brush, clean with solvent, converter, prime and paint.
Take it from a salt water boater. I know corrosion.
LouC is online now
post #10 of 13 Old 09-29-2013, 02:34 PM
Keeslinger31
2005 WK
When I looked at mine it had already been painted by someone and seems to be holding up good idk what they used I assume some rust converting stuff like por15
05 Hemi ome hd/spacers 265/70 Geolandar
winch HLM aspen creek grille defaced wheels
Black WK #126
Keeslinger31 is offline
post #11 of 13 Old 09-29-2013, 05:38 PM
r_p
2005 WK
I just got a 05 Limited (~75K miles, mostly used in WI) and the underside looks very similar to yours.
r_p is offline
post #12 of 13 Old 09-29-2013, 07:41 PM
Atrain1066
2005 WK
When I bought my WK it looked similar to yours underneath - I wire brushed it, and coated it with Rustoleum truck bed liner. It comes in a spray can that works in any direction. I just stayed away from brakes and exhaust and went to town. Still looks brand new under there.
2005 Dark Khaki
5.7L HEMI
QDII
285/60R/18 Nitto Terra Grappler
Atrain1066 is offline
post #13 of 13 Old 09-29-2013, 07:50 PM
ChanWK
2005 WK
Yours doesn't look as bad as mine, it's on my to do list before winter to sand and repaint
ChanWK is offline
