Under hood Lamp /Light - JeepForum.com
post #1 of 6 Old 10-19-2013, 09:18 AM Thread Starter
1EvilHemi
2007 WK
Has anyone installed an Underhood lamp / light on their Jeep? My 99 WJ came with an underhood lamp yet my 07 WK does not. Has anyone installed this? Suggestions are appreciated. Thanks!
Ashley
07 Red Rock Crystal Jeep Grand Cherokee Overland 5.7 QDII. Gibson 3" Cat Back exhaust, modified K&N FIPK cold air intake wet sanded, primed & painted PEM Red Rock Crystal with custom "EVIL HEMI" K&N decal design. Custom Mopar Engine Cover Insert with additional air slots. Removed OEM sticker pin striping. Hawk Performance LTS Brake pads, Stillen cross drilled rotors, OEM calipers custom Duplicolor mix-painted dark red. LED lighted red cup holder rings. 2" Daystar lift kit & Bilstein shocks purchased (awaiting installation).
1EvilHemi is offline
post #2 of 6 Old 10-19-2013, 10:29 AM
caulk04
2008 WK
Waterproof LED strip. Done.
Look up Omelet's rear cargo light project, same thing really.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #3 of 6 Old 10-19-2013, 12:37 PM
sickchilly
2010 WK
I had this on my first JK:
http://www.wkjeeps.com/hoodlamp.htm
I put a super bright LED bulb in it. Real handy with the retractable cord and magnetic base. I haven't put it on the WK yet, but I don't foresee any issues doing so. It turns on and off automatically with the hood angle.
2010 Brilliant Black Crystal Pearl Coat Grand Cherokee S-Limited with various bits 'n pieces... broken in but not even finished!
sickchilly is offline
post #4 of 6 Old 10-19-2013, 05:40 PM
giulio17
Yea I'm about to run led strips in the engine compartment
giulio17 is offline
post #5 of 6 Old 10-20-2013, 01:25 PM
R4TCHET
2005 WK
5050 SMD light strip on the bottom of the hood does wonders. There is only like a 1 foot strip on there. They cost like $20 for 15'
Sent from my Jailbroken iPhone using JeepForum
| (dark)KHAKI WK CLUB MEMBER 17 | 2005 4.7L QTII | JBA UCAs | Modified OME MD 3.5" lift | Rusty's Adj. track bar | 4XG Matrix | 285/70r17 Duratracs | 17" KMC Enduro Wheels | Rola Roof Rack | 21" Bean LED Light bar on Roof Rack | 2 12" Punch P3 Subs | Expanded Sheet Grille | SA Sliders |
R4TCHET is offline
post #6 of 6 Old 10-20-2013, 03:29 PM
yzjwk
2005 WK
Ashley
If you want something cheap and easy , just pick up an underhood light off a wj from the wrecker . they are complete with a gravity switch .Screw it under the hood and Wire it direct to battery .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
