Umm..New IAC Not Fitting? - JeepForum.com
post #1 of 7 Old 10-29-2013, 06:41 PM Thread Starter
WJFrank88
I can't explain this or figure it out so I was hoping somebody on here can..
I recently bought an 06 WK (4.7, QDII) with 75k miles. Today, I decided to see how bad the TB looked thinking the PO never really cleaned it. I cleaned the TB out good with Intake cleaner, didn't take it off to clean it (i'll do that another day, just wanted to see how bad it was)
I also wanted to see how bad the IAC looked, which is where my problems started. I remove the hex bolt, and TRY EVERYTHING to remove it, it seemed glued in there. I took a flat head and pried it outta there after a few attempts. I couldn't believe how hard it was to take off but I got it out so I cleaned it up.
However, no matter which way I tried to slide it back in, it would not budge. I lined the hole up with the one on the TB and tried pushing it in from every angle and it would not slide in! WTF?!! By this point, I'm frustrated as all hell and wind up breaking the top off of it trying to shimmy it in...Again, WTF
Luckily, Advanced had a new one in stock. I went to replace it thinking I wouldn't have the same problem, I was wrong. Again, it wouldn't go in.. So I took the bolt and screwed it in as much as possible, now its crooked. What am I doing wrong?
I should mention I had a WJ, and replaced the IAC on that twice without issue and am fairly handy with a wrench when it comes to jeeps, I just don't know what I'm missing here.
The jeep started, and idles fine with it like it is, I just don't think its good that the IAC sensor isn't going in all the way..
2006|4.7|QDII|OME HD|265/70/17Grabber AT2|D-ring receiver|Magnaflow|3' Firestik|Steel Armadillo
WJFrank88 is offline
post #2 of 7 Old 10-30-2013, 07:56 AM Thread Starter
WJFrank88
Bump
post #3 of 7 Old 10-30-2013, 08:30 AM
caulk04
2008 WK
Looks like a tight o-ring that isn't going into the TB properly. I'm unfamiliar with the single bolt IAC, my old 4.7 was a two bolt setup like it would have been on your WJ (if a 4.7).
If it is an o-ring, try lubricating the ring and bore with some WD-40, oil or similar and wiggle/twist it to seat the o-ring.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #4 of 7 Old 11-01-2013, 09:38 AM
DVB
2006 WK
I feel your pain. I pretty much had to pry mine off as well and had the same problems getting it back on too, I just kind of tapped it back in with a couple small pieces of firewood (that's all I had nearby). Since I had the whole TB off it was easier to work on it. Unfortunately, the minor cleaning didn't help so I am replacing it this weekend. Hope it goes smoother.
2006 4.7 Limited QD II, Stock
DVB is offline
post #5 of 7 Old 11-01-2013, 10:21 AM
DVB
2006 WK
caulk04, I was thinking of using some kind of lubricant too, I just wasn't sure what would be safe to use.
DVB is offline
post #6 of 7 Old 11-01-2013, 11:40 AM
caulk04
2008 WK
Doesn't really matter what you use, you don't need much. Pull the dipstick and wipe a little oil on your finger then on the o-ring for that matter...don't even have to look for anything that way.
caulk04 is offline
post #7 of 7 Old 11-01-2013, 01:48 PM
DVB
2006 WK
Sounds good, thanks.
DVB is offline
