UConnect and Radio stopped working - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > UConnect and Radio stopped working
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!
Unread 12-29-2008, 12:02 PM   #1
ekam
Hey Guys,
I am having trouble with my uConnect device and my Radio. Yesterday I pressed the speak button on the uConnect device, after that the uConnect device would not turn on. MY radio would turn on but the I can not change the volume it's stuck at 0. I have tried the reset for uConnect holding down 2 button and the starting the car. It didn't help. I called Jeep they said go to the dealer and they will do a hard reset by taking out the fuse for the uConnect. Does anyone know where the Fuse box with the uConnect fuse is located. I have a Jepp GC 2007 Laredo.
Thanks
ekam is offline   Reply With Quote
Unread 12-29-2008, 06:35 PM   #2
Floof
2005 WK
I'm not sure about the WK, but fuse boxes are usually under the steering wheel/console area. Most of the time they are covered by a black plastic box, so grab a flashlight and take a look.
Floof is offline   Reply With Quote
Unread 12-30-2008, 08:43 AM   #3
merlinTec
Hi
Fuses are all listed here http://www.wkjeeps.com/wk_fuses.htm reset info here http://www.wkjeeps.com/tsb/tsb_wk_0801406.pdf
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline   Reply With Quote
Unread 01-04-2009, 08:33 PM   #4
HurriJeff
2005 WK
It may not be the best thing to do but I have "RESET" mine twice now by disconnecting the battery. Crude but effective.. <shrug>.
05 Grand Cherokee Limited 5.7 Hemi 265/65/17 Revos, K&N
HEMI CLUB MEMBER #10
Previous Jeeps:
1998 ZJ Special Edition 2wd- Traded
1991 XJ 2.8 2wd Sold
HurriJeff is offline   Reply With Quote
Unread 07-01-2010, 08:04 PM   #5
TheOriginalMdot
The Jeep service bulletin says to remove the Ignition Off-Draw (IOD) fuse for 10 seconds, then replace it. (See merlinTec's post for the fuse info URL.) Turn the ignition on, but do not restart the vehicle. The UConnect system should be reset and work properly.
If this does not work, the bulletin goes on to say the firmware needs to be reloaded from the navigation CD. This appears to require special equipment, so it looks like a job for the dealer. The bulletin indicates there should be a 1/2 hour labor charge.
Good luck.
TheOriginalMdot is offline   Reply With Quote
