Uconnect problem-2005 jeep grand cherokee - JeepForum.com
post #1 of 30 Old 06-17-2012, 06:33 AM Thread Starter
reddyink
2005 XJ Cherokee
My UConnect is all of a sudden dead. Doesn't do anything.. no sound.
Everything else (radio/cd) works fine. So far I have tried to fix it by:
1) Pressing both phone/voice button together when ignition is on position and also off position.
2) Remove Ignition draw off fuse (#27) for couple of minutes (10 seconds to 10 minutes) and put it back.
2a) Replaced Ignition draw off fuse at Autozone (even though the person at autozone said fuse is fine)
3) Took out the battery for sometime (couple of hours) and connect it back. All the radio/cd setting are reset but Uconnect doesn't do anything.
4) Pulled out uconnect cables from rear view mirror and put it back to make sure connect is tight.
Appreciate any suggestions on how to fix it.
Thank you for your time.
reddyink is offline
post #2 of 30 Old 06-17-2012, 10:50 AM
getoffmyland
Same with mine (with RAR radio, same as RAQ)
So far tried the fuse
Have been searching and there might be a dealer update to be done to fix it
http://www.xkjeeps.com/tsb/tsb_xk_0801406.pdf
what radio have you got?
getoffmyland is offline
post #3 of 30 Old 06-17-2012, 11:53 AM Thread Starter
reddyink
2005 XJ Cherokee
On the unit it say CD R.D.S
On the window price sticker it says.
Sirius satellite radio RSA
Uconnect Handsfree com RSP
6CD/Full map GPS Nav REC
Thanks for the offer to help!
reddyink is offline
post #4 of 30 Old 06-17-2012, 11:42 PM
trax95008
2006 XK Commander
REC is the model of your radio just FYI
trax95008 is offline
post #5 of 30 Old 06-24-2012, 01:29 PM Thread Starter
reddyink
2005 XJ Cherokee
Tried couple more things but still uconnect not responding. Appreciate any help
reddyink is offline
post #6 of 30 Old 06-24-2012, 02:40 PM
90grandoneer
90grandoneer's Avatar
2006 WK
The U-Connect module is behind the passenger side kick panel. You may want to check mounting and connections.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, TruFlow Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, Transgo Shift Kit, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam w/6* advance/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, TEA ported/milled heads, SRT Reps with 265/45&295/40X20's.
90grandoneer is online now
post #7 of 30 Old 06-25-2012, 11:39 AM
getoffmyland
I had mine out over the weekend to check it.
All connections were fine. I took the plastic cover off and there didnt look to be anything wrong with the electronics like burned out things.
next time I am taking radio out and checking connections behind there
post #8 of 30 Old 06-25-2012, 06:31 PM
90grandoneer
2006 WK
The bezel just pulls off, exposing the radio. Easy to remove. Just be careful. One guy dropped it on the shift lever and broke the screen. After doing that, he recommended putting it in "D" while removing the Nav/radio.
post #9 of 30 Old 06-28-2012, 08:28 PM
HurriJeff
2013 WK
Mine does this sometimes and I just disconnect the negative terminal on the battery for about 2 minutes and then reconnect it and u-connect starts working again. Thats what has worked for me.
05 Grand Cherokee Limited 5.7 Hemi 265/65/17 Revos, K&N
HEMI CLUB MEMBER #10
Previous Jeeps:
1998 ZJ Special Edition 2wd- Traded
1991 XJ 2.8 2wd Sold
HurriJeff is offline
post #10 of 30 Old 07-01-2012, 09:32 AM Thread Starter
reddyink
2005 XJ Cherokee
Hello, Where should I find side kick panel for 2005 jeep? On the driver side there is panel under the steering wheel but on the passenger side there is glove box.
There is no panel under the glove box.
thanks for the help!
reddyink is offline
post #11 of 30 Old 07-01-2012, 09:49 AM
getoffmyland
its nearer to the floor, you may have to remove the plastic from the door sill first
post #12 of 30 Old 07-01-2012, 01:49 PM Thread Starter
reddyink
2005 XJ Cherokee
All the connections are fine in passenger side kick panel. Still no response at all from Uconnect button. When I press it, it's like dead.
So far I have done:
1) Took out Ignition draw off fuse for few minutes (20 minutes) and put it back several times.
2) Replaced ignition draw off fuse
3) Tried to reset by pressing both Phone/Voice buttons with ignition off position and on positions as mentioned here.
4) Removed the battery connections for 1 hour and put it back.
5) Checked all the connections on passenger side kick panel and driver side under the steering wheel.
Still not able to make it work. Dealer want $160 to check the problem and don't know how much they will charge for the repair.
Now I have VES error, Navigation says can't read the dvd-rom.
Greatly appreciate any suggestion on what I should do next!
reddyink is offline
post #13 of 30 Old 07-01-2012, 03:02 PM
90grandoneer
2006 WK
Maybe it's time to unplug the harness from the mirror and try to "ring out" the wiring for the U-Connect button. Do you have access to the Factory Service Manual? I think you can find the info. on line. If not, I'll see if I can find something on it.
post #14 of 30 Old 07-01-2012, 03:16 PM Thread Starter
reddyink
2005 XJ Cherokee
Thank you for the reply. I unpluged the harness from mirror 3 times to make sure it's connected properly.
Appreciate if you can provide a link for Factory Service Manual to fix this.
Many thanks
reddyink is offline
post #15 of 30 Old 07-01-2012, 03:20 PM
90grandoneer
2006 WK
I don't know the link to it, but I've heard folks saying there is one. I have the actual CD and a hard copy too. Try a search and in the mean time I'll try to look it up.
2005 Jeep Grand Cherokee Sway Bar problem? kwake WK Grand Cherokee & XK Commander Forum 9 05-08-2012 09:44 AM
2005 Jeep Grand Cherokee REC Radio/Uconnect calcal10 WK Grand Cherokee & XK Commander Forum 0 08-11-2011 08:38 AM
2005 Jeep Grand Cherokee AC Problem jcarranco WK Grand Cherokee & XK Commander Forum 16 08-04-2011 02:06 AM
Steering Problem, 2005 Jeep Grand Cherokee BinaryTracks ZJ Grand Cherokee Forum 7 07-30-2006 09:55 PM
2005 Grand Cherokee Problem RoughDobermann ZJ Grand Cherokee Forum 5 06-03-2005 04:00 PM
