Two general questions about my jeep - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Two general questions about my jeep
Engo winches available at www.rockridge4wd.com! Free shippThe Original 3/8" Ruffstuff Diff Cover!The Ruffstuff NOT Universal 4 Link Kit!
Unread 05-22-2014, 03:58 PM   #1
Dougyfresh
2007 FSJ Cherokee
I have a 2007 WK 4x4, my first question is this, when I purchased it the previous owner only had one key for it, if I were to go to walmart and have another key made there would that work to start my engine or is there an anti theft chip or something in the original keys? Could a replicated cut key at LEAST unlock my door?
2nd question is, if I take off the little air dam on the bottom of my front bumper to gain a little ground clearance in the front will it noticeably affect my gas mileage? Thanks for your time.
Dougyfresh is offline   Reply With Quote
Unread 05-22-2014, 05:40 PM   #2
Goldenknob
2007 WK
If you get a key cut at WalMart then only use it to open the doors, it won't start it.
if you remove the lower air dam it should increase your mpg by 1 maybe?
Goldenknob is offline   Reply With Quote
Unread 05-22-2014, 06:47 PM   #3
IIMacGyverII
IIMacGyverII's Avatar
2007 WK
This is the full key you will need to unlock and start the car. A standard "Walmart" key will just unlock the doors.http://www.amazon.com/dp/B00DP3DGR8/...I1TKH0MJKZ3DBL
Yes it will by a surprising margin. Sometimes up to 5 mpg but it's probably more like 2-3.
2007 WK CRD Limited Fully Loaded. GDE Hot Tune, SWK Member 115
1996 ZJ Limited -RIP
N23 Recall Victim
IIMacGyverII is online now   Reply With Quote
Unread 05-23-2014, 02:28 PM   #4
Dougyfresh
2007 FSJ Cherokee
So when you say it could change by up to 5 mpg you do mean that it could get up to 5mpg less, meaning WORSE gas mileage right?
Unread 05-23-2014, 08:45 PM   #5
CavallinoRed
2006 WK
You will get a bit better mileage with the lower deflector in place but its real easy to pull off and put back on when needed.
CavallinoRed is offline   Reply With Quote
Unread 05-23-2014, 10:13 PM   #6
modernblueWK
You will LOSE mpg with it off. Science....
2008 WK 4.7 245/70-17 Grabber AT2 - Magnflow - JBA - G2 - Steel Armadillo - MLL's
Blue WK club #4
modernblueWK is offline   Reply With Quote
Unread 05-26-2014, 03:15 PM   #7
Shafer57
2006 WK
You need two keys to program additional keys into your vehicle. If you don't have two keys, then you can either buy one online and take it to a dealer/locksmith for programming, or buy one from a locksmith/dealer and have them program it for you all in one shot.
Dodge Dakota R/T 360ci Small-block _sold_
Jeep GC 5.7L Hemi- Magnaflow Cat-Back, BT Catch Can, 20" Gloss black SRT Reps
275/45R20 Nexen Roadian, Blacked out, 180 Stat _SOLD_
2008 335i Twin-Turbo
Shafer57 is offline   Reply With Quote
