Twistedlizard72's Build and other Adventures - Page 4 - JeepForum.com
post #46 of 109 Old 06-19-2013, 05:49 AM
paroxysym
2007 WK
Originally Posted by twistedlizard72 View Post
If I remember right, it was vehicles made after 2003/2004? If I get some spare time, I will give them a shout and get the scoop.
The Trans-go kits come in two varieties, the light version which can all be accessed through the oil pan. That version is the cheaper one and upgrades the accumulator plate along with a few solenoid springs and goodies. The bigger kit is usually around the $100 mark and comes with improved spring clips. This kit you have to pull the transmission to get everything on.
I should have it back Friday and will report.
which one id you go with?
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #47 of 109 Old 06-19-2013, 02:23 PM Thread Starter
twistedlizard72
2007 WK
I did the big kit since the transmission is out and in pieces.
Kevin K.
twistedlizard72 is offline
post #48 of 109 Old 06-19-2013, 03:28 PM
Jeepforthewin
2010 JK Wrangler
You'll have to let us know how the difference is once your transmission is back in!
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #49 of 109 Old 06-23-2013, 09:38 PM Thread Starter
twistedlizard72
2007 WK
Here's the scoop on the trans rebuild and Trans Go shift kit...I LOVE IT!!
All new parts went into the transmission including a shift solenoid body. The kit really made a good difference. It don't really think it should be classified as a shift kit, more like a "fix what Mopar didn't" kit. It holds onto 1st gear a little longer at WOT. No waiting for the gear to engage when shifting from park. Up shifts are smooth and seamless as well as down shifts. You really have to pay attention to feel the shifts because it is so smooth now. Best way to describe it is, Solid. Running better than the day it came off the production line.
At this point, I highly recommend this kit, especially if you have the transmission out of the vehicle. If not, put in the shift kit accessible through the pan and save the rest for when the trans has to be rebuilt.
One thing to note, the transmission filter only had 9,000 miles on it and it had already split. Not sure if that had anything to do with the day I broke it, or if that was part of why it broke, but the filter failed....and rather early at that. So keep an eye on that fellow WK Jeepers.
Kevin K.
post #50 of 109 Old 06-25-2013, 06:23 AM
paroxysym
2007 WK
so the solenoid pack needed replaced as well or you decided to replace those regardless?
OEM+
post #51 of 109 Old 06-25-2013, 09:50 AM Thread Starter
twistedlizard72
2007 WK
I had it replaced regardless. I kept the old one to have an emergency spare around.
Kevin K.
post #52 of 109 Old 10-16-2013, 02:58 PM
paroxysym
2007 WK
any updates?
OEM+
post #53 of 109 Old 12-10-2013, 12:55 PM Thread Starter
twistedlizard72
2007 WK
Got home today from a 5 month deployment and fired up the Jeep. Running good, took a minute to run out the flat spots in the tires. Trans is impeccable. I was however given the gift (by the Jeep) of 4 new DTC's.
1. P1128, which I thought I had solved when I replaced all 4 O2 sensors 7 months ago.
2. U0001- Can C Bus Circuit (oh god, here we go…..)
3. C1407-TRANSFER CASE BRAKE CONTROL CIRCUIT LOW
4. C1405- TRANSFER CASE RANGE POSITION SENSOR CIRCUIT HIGH
So needless to say, there is going to be some work going down. Just hope it doesn't strand me being I got quite a few miles to log over the holidays. I do plan to get my Aspen Creek recovery shackles on here in the next few days.
Kevin K.
post #54 of 109 Old 12-10-2013, 01:27 PM
Jeepforthewin
2010 JK Wrangler
Welcome back!! Glad you are safe and sound now. Hooefully the codes are thrown by something simple
post #55 of 109 Old 12-10-2013, 01:41 PM
paroxysym
2007 WK
welcome back, the DTCs are your jeeps way of saying it missed you lol.
OEM+
post #56 of 109 Old 12-10-2013, 08:00 PM Thread Starter
twistedlizard72
2007 WK
Thanks, it's great to be home.
Not sure what was up with the DTC's, I went and got the driveline measured and right after that they codes cleared. Just keep an eye on it, I really don't want that T-case computer re-flash.
Kevin K.
post #57 of 109 Old 12-10-2013, 08:08 PM
ttusqrl
2005 WK
If you have been gone for that long, I wonder if the variety of codes is due to a failing battery.
2005 WK 5.7 ORT | Mod SL (OME struts & 990s) | JBA UCAs & Discos | Saguaro Front Bumper | Warn Zeon 10s | 285/70/17 BFG TA KO | AIRAID CAI | Gibson 3" Exhaust | DiabloSport Intune | JL Stealthbox
ttusqrl is offline
post #58 of 109 Old 12-11-2013, 12:05 AM Thread Starter
twistedlizard72
2007 WK
That crossed my mind too. It is an ancient battery.
Kevin K.
post #59 of 109 Old 12-11-2013, 06:34 AM
paroxysym
2007 WK
so with the 285s, you just did the procal and the transgo kit? no superchips?
hows performance/mpgs without a tuner?
OEM+
post #60 of 109 Old 12-11-2013, 07:12 AM Thread Starter
twistedlizard72
2007 WK
I do have a super chips but haven't use it for calibration, and I don't have the trans tuner app. I run the performance 87 tune majority of the time. Performance is good, considering it's the 4.7 and my mixed driving has been yielding mid 14's (EVIC) mpg since I got home. Best I have seen on the highway is 19. Haven't tried at stock settings yet.
Kevin K.
