The turbo is dead - JeepForum.com
post #1 of 17 Old 11-04-2013, 09:43 PM Thread Starter
b52rule
2007 WK
The turbo is dead
My son changed out #5 glow plug yesterday (Code P0675) and found this something went thru the turbo.
Just for grins........the P0675 code is back.
Rebuilt turbo from a local re builder here in Oceanside....about $600
b52rule is offline
post #2 of 17 Old 11-05-2013, 04:07 AM
rsq41
2007 WK
#5 Glow Plug
I have not done mine yet.. But from what I have read on the forum, it seems that the best bet is to replace all 6 glow plugs AND the glow plug controller to make sure the #5 issue is resolved.
07 CRD
rsq41 is offline
post #3 of 17 Old 11-05-2013, 04:52 PM
terrasmak
2007 WK
Jeep turbo by terrasmak, on Flickr
What my dads turbo looks like. Then the glow plug, he got about 10 good starts on it with the code cleared. Looks like module time, I just swapped the module on mine, no code for over a week now.
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline
post #4 of 17 Old 11-06-2013, 08:09 AM
jediknight
2008 WK
Originally Posted by terrasmak
Jeep turbo by terrasmak, on Flickr What my dads turbo looks like. Then the glow plug, he got about 10 good starts on it with the code cleared. Looks like module time, I just swapped the module on mine, no code for over a week now.
What happend there ??!!
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #5 of 17 Old 11-06-2013, 09:12 AM
ryann04
2008 WK
did you suck a squirl through your turbo by accident or what? Those look like they took a beating.
This is why I try not to run anything but dry filters.
2008 - Jeep Grand Cherokee - 3.0L CRD - Quadra Drive II - GDE Hot-Tune - OME HD Lift Kit - OEM Full Steel Skids
Blue WK Club Member #42 // DIESEL FTW !!!! -Ryan
ryann04 is offline
post #6 of 17 Old 11-06-2013, 09:28 AM Thread Starter
b52rule
2007 WK
No idea what happened. My son was changing out #5 glow plug, pulled the intake tube for grins and then I heard "Dad, look what I found!" We checked the filter and any pathway that vcould lead to injestion, but found nothing. I'll fix it this weekend.
Any idea how long that may take?
Running a K&N filter, and a GDT
b52rule is offline
post #7 of 17 Old 11-06-2013, 10:12 PM
Tango.
2008 WK
Do you have the aluminum plug in the turbo intake tube?
I saw some people plugging the 1/2" hole in the turbo intake tube (about 2" infront of the turbo) with some ACE hardware rubber plug with a nut and bolt... and if that is there that could have caused it if it came apart.
Factory runs a rubber tube from the crank case breather hole on the passenger valve cover up by the firewall to the turbo intake tube, a couple inches in front of the turbo, with a small heater inline of the tube.
Tango. is offline
post #8 of 17 Old 11-07-2013, 12:08 AM Thread Starter
b52rule
2007 WK
I'll take a look in the AM but I don't remember any mods to the system. I'm thinking my son would have caught that as he has the same jeep.
b52rule is offline
post #9 of 17 Old 11-07-2013, 01:44 PM Thread Starter
b52rule
2007 WK
Checked this AM.
"Factory runs a rubber tube from the crank case breather hole on the passenger valve cover up by the firewall to the turbo intake tube, a couple inches in front of the turbo, with a small heater inline of the tube."
That what is there, the factory setup.
b52rule is offline
post #10 of 17 Old 11-08-2013, 06:27 AM
terrasmak
2007 WK
Originally Posted by b52rule View Post
Checked this AM.
I didn't look at the heater in the inlet tube, maybe the heater came apart and FOD'ed out the turbo. You just have to pull the end cover to get to the heater.
post #11 of 17 Old 11-08-2013, 01:16 PM
Radcrd
2007 WK
Make sure the K&N fits properly. I have seen numerous filters with bad fitments allowing dust particles to bypass the filter and erode turbo vanes. None as bad as yours however.
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline
post #12 of 17 Old 11-08-2013, 02:02 PM
ingikarl
2008 WK
Where to buy rebuilt turbo?
Checked this AM.
Hi,
I had the same problems as discussed here, new glow plug controller installed and now I need a new turbo (mine looks the same as in the picture here in this thread). Have you any good suggestions where t buy a rebuilt turbocharger? I am looking around for options. Seems hard to get rebuilt with original parts.
ingikarl is offline
post #13 of 17 Old 11-08-2013, 06:53 PM Thread Starter
b52rule
2007 WK
Pure Turbos
<li class="mod" style="clear:none">
Address: 333 Airport Rd, Oceanside, CA 92058
Phone:(760) 721-7669
Hours:
Friday 9:00 am – 5:00 pm -
b52rule is offline
post #14 of 17 Old 11-08-2013, 06:56 PM Thread Starter
b52rule
2007 WK
I pulled the heater off the breather tube. There is nothing inside the heater part, just slick orange plastic. Is there anything supposed to be inside that short piece of tube?
b52rule is offline
post #15 of 17 Old 11-08-2013, 09:40 PM
terrasmak
2007 WK
If I was back in the states I would easy pull mine off and look. Should have checked last weekend when I was down in SoCal.
