TSB 18-006-10B MDS Driveability Improvements - JeepForum.com
post #1 of 4 Old 09-23-2013, 03:33 PM Thread Starter
corswandtm
2007 WK
Will this help my Hemi even if I am running the Superchips tuner?
I eventually need to have them re flash my system for errant "Service Tire Pressure System" alert. Should I have them do all applicable updates while Im there? I will return my Jeep to Stock tune before I take it. My question is, does the Superchip negate the dealers PCM changes?
2007 WK Red Rock Limited - 5.7 HEMI w/QD-II - Stainless 22" Magnaflow muffler - AFE Stage 2 CAI - Bilstein HD shocks/struts - JBA Strut Spacers - 245-70/17 Firestone Destination AT
corswandtm is offline
post #2 of 4 Old 10-07-2013, 10:21 AM Thread Starter
corswandtm
2007 WK
Bump
post #3 of 4 Old 10-07-2013, 12:21 PM
hearld5000
2011 WK
Why would you even risk it for something that takes two minutes? Flash it back to stock before taking it into the dealer.
hearld5000 is offline
post #4 of 4 Old 10-07-2013, 01:13 PM
yzjwk
2005 WK
Yes , make sure you don't go into the dealer with the Jeep tuned . It will cost you $$ to have superchips unlock your programmer .
No the superchips doesn't negate the TSB flash , but i believe you will have to use the superchips update software to erase your stock profile . then the next time you use the SC it will load a new stock program .
Will it help ? I guess that depends if you feel the MDS kick in excessively or harshly now .. I find that depending on which tune i use the SC programmer will either make MDS come on more , or less frquently . Or you can use the programmer to turn MDS completely off if you want .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
