To trim or not to trim an '08 limited bumper... - JeepForum.com
post #1 of 6 Old 06-20-2013, 11:13 AM Thread Starter
08hemi
2008 WK
Trying to work up the nerve to trim my bumper either to the first crease or the second... I've been searching the forums for an hour now and haven't seen what i'm looking for. Has anyone done it?
08hemi is offline
post #2 of 6 Old 06-20-2013, 12:18 PM
bhawks28
2014 JK Wrangler
I'm not sure if you know this or not, but that lower air dam can be removed with a few clips. Here's what it looks like on an 08+ bumper
2014 JKU Rubicon
bhawks28 is offline
post #3 of 6 Old 06-20-2013, 12:28 PM Thread Starter
08hemi
2008 WK
Interesting... I haven't seen that before. I figured I would lose the fog light pocket if i took it off... but the doesn't look half bad. Thanks!
08hemi is offline
post #4 of 6 Old 06-20-2013, 09:11 PM
jjarvis0007
2005 WK
I can't stand the look of my plastic piece below the bumper. I think I'll take it off this weekend?
jjarvis0007 is offline
post #5 of 6 Old 06-20-2013, 09:20 PM
suzieque
2008 WK
I remove the lower section when I off-road. I only use 4 out of the 7 clips just so its quicker to remove. A bit of a nuisance to remove and install and store the lower section, but I find the 08 WK is much more stable when towing if the lower section is installed, I guess it pushes more air around the vehicle rather than letting the air go underneath.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #6 of 6 Old 06-20-2013, 11:04 PM
modernblueWK
I trimmed mine to the first crease so 1-2 inches off.
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
