Transmission Shift Module?? - JeepForum.com
post #1 of 14 Old 09-06-2012, 05:38 AM Thread Starter
ItsMeKO3
Had the dealer look at my Jeep yesterday because my check engine light came on last week. Not sure what the exact code was, but my brother in law told me I am going to need a new Transmission Shift Module. I'm not exactly sure what this does, or anything about it. He said he doesn't think it needs to be done immediately, but the part is like $800. The CEL went off the day after it came on, and it seems to be driving alright. Anyone else have any issue or know anything about this? Thanks.
2007 JK
ItsMeKO3 is offline
post #2 of 14 Old 09-06-2012, 06:42 AM
JackB1
2008 WK
I do not but would be interested in hearing how many miles are on your WK.
JackB1 is offline
post #3 of 14 Old 09-06-2012, 07:20 AM Thread Starter
ItsMeKO3
Just hit 105K.
Sent from my DROID4 using JeepForum
2007 JK
ItsMeKO3 is offline
post #4 of 14 Old 09-06-2012, 07:54 AM
nostaw22
I had the transmission shift module go on my '07 WK (about 18 mo ago?), with less than 30k mi on it. Was covered by my Chrysler extended service agreement, so a rental was provided and it only cost me $100, but I think they said it was ~$800 for the part.
As I recall, the circumstances were:
GF was driving the WK (is her DD) when it happened and I wasn't there. Said she drove down our street and through a big puddle of standing water (which usually collected due to drainage issues, is 2-4" deep), stopped at a stop sign and the CEL came on / vehicle went into limp mode.
She called me because "it wasn't driving right" (e.g. limp mode) and I had her take it straight to the dealer nearby... rest is history.
JW
1998 XJ - built for offroading
2007 WK CRD - DashHawk, for towing the XJ
nostaw22 is offline
post #5 of 14 Old 09-06-2012, 08:15 AM Thread Starter
ItsMeKO3
Wow that's weird. Unfortunately mines not covered under any warranty. Its still driving fine, so I guess it hasn't **** the bed yet. Have you had any issues since it was replaced? Doubtful because you only had 30K on it. I'm just concerned that if I replace it, is this going to be the beginning of transmission problems...?
2007 JK
ItsMeKO3 is offline
post #6 of 14 Old 09-06-2012, 08:59 AM
nostaw22
No issues (with the transmission) since the TSM was replaced. The factory warranty may have covered it, not the extended one, but I don't remember for sure. It may have been more like ~2 yrs ago, now that I think about it.
WK has ~45k mi on it now. We got this WK in spring '09 with ~850 mi on it, which is why it has very low mileage for its age. We have been putting 10k-12k mi / yr on it since we got it.
JW
nostaw22 is offline
post #7 of 14 Old 09-12-2012, 11:27 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Here's some info on the TCM from the Service Manual:
(Ignore if not interested)
The transmission control module (TCM) (1) is mounted to the dash panel (2), under the dash panel silencer pad, just to the right of the steering column.
The electronic control system consists of various components providing inputs to the TCM. The TCM monitors transmission sensors, shifter assembly, and bus messages to determine transmission shift strategy. After shift strategies are determined, the TCM controls the actuation of transmission solenoids, which controls the routing of hydraulic fluid within the transmission, by moving a sequence of four valves to make a shift occur.
The system performs its functions based on continuous real-time sensor feedback information. In addition the TCM receives information from the rest of the vehicle over the CAN C bus. The CAN C bus is a high-speed communication bus that allows real time control capability between various controllers. Most messages are sent every 20 milliseconds. This means critical information can be shared between the transmission, engine, and ABS controllers. The CAN C bus is a two wire bus with a CAN C Bus (+) circuit and a CAN C Bus (-) circuit. These circuits are twisted pairs in the harness to reduce the potential of radio and noise interference.
The transmission control system automatically adapts to changes in engine performance, vehicle speed, and transmission temperature variations to provide consistent shift quality. The control system ensures that clutch operation during up-shifting and downshifting is more responsive without increased harshness. The TCM activates the solenoid valves and moves valves in the valve body to achieve the necessary gear changes. The required pressure level is calculated from the load condition, engine speed. Vehicle speed (from ABS module) and transmission oil temperature, matched to the torque to be transmitted. Power for the transmission system is supplied through the shifter mechanism (no transmission control relay).
______________
Is the above what you are referring to? Did you get paperwork back from the dealer, but it doesn't show which code?
JeepCares is online now
post #8 of 14 Old 09-12-2012, 12:36 PM Thread Starter
ItsMeKO3
I didn't get any paperwork so I don't have any codes. My brother in law is a salesman at the dealership, so he took it for me one day and had them look at it. There was probably no paperwork because I think they did it off the books. Probably on one of the guys lunch break, just to see what the CEL was on for. It had been driving fine before the light, and still driving fine now. So we decided not to do anything about it right now.
2007 JK
ItsMeKO3 is offline
post #9 of 14 Old 09-13-2012, 03:19 PM
robpp
______________
thats awesome. but its his SHIFT MODULE not CONTROL MODULE. read the OP/
the shift MODULE is the shifter itself and its housing.......the thing that you move to different letters that makes the jeep go LOL
and look who is posting/ WTF no wonder these things are as they are <smh>
Rob 007 Laredo 4.7 FFV 27X; DeBadg'd; Zaino'd; SRT8 Grill, Pedals, Strut; ClearBra; WeatherTech; LED Reverse; HIR Hi/Lo; SS Fog; Stealth Turns; 15% Tint; Stubbie; Rear Spoiler; Magnaflow; V1; 22Elite Console/Visors; Body Kit; Color Match Everything; TintedTails; K&N 63; Front Skid; QuickOilDrainValve; BatteryTender; SuperChips 91; Bilstein; Billet Window Switches; Greasable Addco Sways; RamMedic Hood; Fastman TB; BWoody Links; Kicker Upgrade w/Single Sub; AVIC F90BT Hacked; NeffyWrap ABCD; Putco LEDs; Viper 20s w/255/50; R1 Slot/Dimple w/Hawk Pro Ceramic; Whistler Mod w/FlashTech Halos
robpp is offline
post #10 of 14 Old 09-13-2012, 03:24 PM
robpp
hey OP
its the shifter itself. is you try a search you should find lots of posts on cleaning the contacts and boards inside the shifter. all you need is contact cleaner ($8 at THD) and some basic tools.
robpp is offline
post #11 of 14 Old 09-13-2012, 03:34 PM Thread Starter
ItsMeKO3
Alright I'll have to see if I can find anything through a search. I googled it and read a couple people saying that's what they had done. Hopefully it'll take care of the problem. Thanks Rob.
2007 JK
ItsMeKO3 is offline
post #12 of 14 Old 09-14-2012, 09:34 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
sorry - glad you guys are paying attention...
Definitely not a technician/engineer here (and never claimed to be)
post #13 of 14 Old 09-14-2012, 10:19 AM
robpp
no guarantee but for less than 10 bux and some time its worth a shot.
robpp is offline
post #14 of 14 Old 09-14-2012, 10:35 AM Thread Starter
ItsMeKO3
Absolutely. Thanks again man.
2007 JK
ItsMeKO3 is offline
Electronic Shift Module MassRedneck WK Grand Cherokee & XK Commander Forum 5 06-03-2016 09:13 AM
Gear Shift Module wim3324 WK Grand Cherokee & XK Commander Forum 11 08-30-2011 08:07 PM
4x4 Shift Module/Motor? brsox88 WK Grand Cherokee & XK Commander Forum 8 08-29-2011 09:57 AM
94 ZJ electronic shift module? THLL ZJ Grand Cherokee Forum 2 03-23-2011 07:26 PM
gear shift module problems avolchko ZJ Grand Cherokee Forum 0 01-26-2011 03:03 PM
