Transmission Rebuilt - Still Rough Idle - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Transmission Rebuilt - Still Rough Idle
Rough Country Deals at JeepHut.comSave at JeepHut on Smittybilt Soft topsUp to $75 Cash Back on Your ARB Fridge Freezer Purchase
Unread 06-24-2014, 09:26 AM   #1
BmoreGC
2005 WK
Frustrated is an understatement.
2005 Grand Cherokee Limited with 136k miles. Just had the trans rebuilt, which included a new torque converter. We were getting codes p0700, p0740 and p0308 prior to this. No more codes.
We still have a rough start up, where it seems to barely turn over. Sometimes need to turn the key more than once.
We have had plugs, ignition coils, fuel injectors and various sensors replaced in the last 6 months. Compression test was fine.
Any suggestions to get this problem fixed?
BmoreGC is offline   Reply With Quote
Unread 06-24-2014, 09:34 AM   #2
Goldenknob
2007 WK
Barely turning over could be a starter issue.
Goldenknob is offline   Reply With Quote
Unread 06-24-2014, 09:41 AM   #3
spennerus
So does it idle rough all the time? Or is it only hard to start?
Copper core plugs?
Have you checked fuel pressure?
If turning over slowly I would look at battery
If O2 sensors have never been replaced you might consider that (won't help with hard start though, only poor running/gas mpg possibly)
spennerus is offline   Reply With Quote
Unread 06-24-2014, 09:52 AM   #4
BmoreGC
2005 WK
Battery replaced less than 12 months ago
It is a rough start, and a rough idle. If we give it gas and rev the motor while in park/neutral, it "misses" when it hits about 3,500 rpms.
The plugs were Champion copper if I recall correctly.
We have not done O2 sensors yet, nor have we looked at fuel pressure.
Thank you for your suggestions.
Unread 06-24-2014, 10:02 AM   #5
spennerus
Couple other things that come to mind to check are:
PCV valve
Vacuum leaks
Unread 06-24-2014, 10:06 AM   #6
tjkj2002
2002 KJ Liberty
The trans has nothing to do with a rough idle.
That last code is cyl# 8 misfire which is related.Bad cats can also cause what you are feeling but are not bad enough yet to trip the 2 cat codes(P0420 and pP0430).I've seen in multiple times with the 3.7/4.7 Jeeps.
tjkj2002 is offline   Reply With Quote
Unread 06-24-2014, 10:42 AM   #7
BonesWK
2006 WK
x2
Why did you rebuild the trans, was it shifting wrong??
Ryan
2006 Black WK Limited 4.7 4x4 QD II -- RR 2.25" Lift - JK Moabs - 32" Wildpeaks - Rear OME Shocks - AFE Stage 2 Intake - Saguaro 4x Front Shackles - 1-1/2" Wheel Spacers - Tail Light Guards - CB - 4' Firestik - Rola Roof Rack - Exhaust
If you want to achieve greatness, stop asking for permission
Chive On
BonesWK is offline   Reply With Quote
Unread 06-25-2014, 05:43 PM   #8
tom19511
2006 WK
Here is your misfire
http://www.obd-codes.com/p0308
Tom19511
tchristopher1@wowway.com
2006 Grand Cherokee Laredo 3.7
2007 Liberty Sport 3.7
tom19511 is offline   Reply With Quote
Unread 06-29-2014, 01:47 PM   #9
ZWilson07
Cowboy
ZWilson07's Avatar
2008 WK
Hope you get it worked man. Any news yet?
Im having similar issues but I think mine is stemming from my 013C and 0340 codes by a bad passenger side cat.
2008 WK Overland 5.7 Hemi 4x4 QD2
Everything I need, plus a lot more I don't.
Black WK Club Member #154 || Hemi Club Member #89
ZWilson07 is offline   Reply With Quote
Unread 06-30-2014, 10:12 AM   #10
BmoreGC
2005 WK
Update: The Transmission was Rebuilt because it threw 3 transmission codes, and suddenly one day it was hesitant to go forward or reverse when either D or R was engaged. A Dangerous Situation to be on when out on the road. We took it to an independent shop we've taken other vehicles to, and they've always been fair and honest with us.
As for the rough idle, I just ordered 3 new 02 sensors from Rock Auto. After doing some research, I found these should be replaced at 100k, and the vehicle now has 136k. I also learned that you should definitely stick with OEM O2 Sensors. All 4 cost a total of $250 at Rock Auto dot com. It would of been $400+ at Auto Zone, and I can only imagine what the Stealership would charge. The sensors should be here soon - fingers crossed, it will solve the problem.
