Transmission problem in reverse - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Transmission problem in reverse
Save 17.76% for the 4th of july with ruffstuff specialtiesIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSave on AEM Intakes from XT!
Unread 07-01-2015, 08:19 AM   #1
ChanWK
2005 WK
Hey guys, so when I shift my car from drive to reverse I've been getting a grinding noise lately. Can't seem to figure it out I've done some research and heard it might be a pinion bearing. Any one else encounter this. I have a 2005 WK with the hemi and Qudra drive 2.
Thanks
Cody
ChanWK is offline   Reply With Quote Quick reply to this message
Unread 07-03-2015, 08:47 AM   #2
90grandoneer
2006 WK
Where does it sound like the "grinding" is coming from.......trans. area, diff. area, xfer case area, etc.? Just a few questions to get a little more info:
---Have you checked the fluid level and fluid condition of the transmission, xfer case and diffs.?
---Does it happen when you shift from reverse to drive?
---Does it do it just on the gear transition, or when its moving in reverse too?
---How does the transmission upshift/downshift?
---Any roughness, slipping, hesitations from the trans.?
---When is the last time the transmission, xfer case and diffs. have been serviced?
I can't imagine it being a pinion bearing grinding. If it were a bearing I would think it would be more a growl or continuous noise both going forward and in reverse, not just when shifting from drive to reverse. Not having heard it, there are a number of things that could be causing it......driveshaft(s), transfer case, transmission, front diff. bushings, either or both diffs., just to name a few.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline   Reply With Quote Quick reply to this message
