Transmission over temp - JeepForum.com
post #1 of 18 Old 01-26-2012, 04:23 PM Thread Starter
Cinna
2007 WK
Ok, I know this issue is somewhere on here but I'm getting mixed answers. I have a 2007 GC laredo, yesterday morning it would not start, it didn't turn over at all. Took off the terminals off the battery to start it and it did but would not start again, after self diagnosing it I started at the starter, had it replace started- turned it off would not start again. So if anyone can help it be appreciated it.
Cinna is offline
post #2 of 18 Old 01-26-2012, 11:57 PM
tom58
how about the electronic immobilzer, have you tried to start with the other key, yet???
tom58 is offline
post #3 of 18 Old 01-27-2012, 12:15 AM Thread Starter
Cinna
2007 WK
Thank you for your response, I thought that to. I'm going to try that tomorrow.
Cinna is offline
post #4 of 18 Old 01-27-2012, 05:57 AM
AJeepZJ
2006 WK
Even if it is the transmission being over temp - The engine should still start. So it is not your transmission. My dash flicks 'Trans over Temp' at the same time I turn the engine over for the last 1.5 years that I've actually paid attention to it. But i'm not really sure what your issue could be - I am curious, so I will probably do a little bit of asking around - You can also try sending WK guru Mrtosh a pm.
All Gear, No Skill.
AJeepZJ is offline
post #5 of 18 Old 01-27-2012, 11:11 AM Thread Starter
Cinna
2007 WK
I did try the spare key no luck had it towed this morning.
Cinna is offline
post #6 of 18 Old 01-27-2012, 11:16 AM Thread Starter
Cinna
2007 WK
This is the first time I noticed it, it only showed up when I took the key out. I did the "key trick" got code 11 I think. you said "You can also try sending WK guru" what do you mean, please excuse me I fairly new, and I don't post much. I'm a lurker. Thank you for your response.
Cinna is offline
post #7 of 18 Old 01-27-2012, 11:19 AM Thread Starter
Cinna
2007 WK
Ok I understand sorry.
Cinna is offline
post #8 of 18 Old 01-27-2012, 01:07 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
This is the only thing I can find that might be related - and I don't know if it relates to your vehicle.
Diagnosis:
Vehicle will not crank; battery and starter system are working properly.
Discussion:
The Electrohydraulic Control Unit Assembly of the NAG1 transmission contains a temperature sensor
to monitor the transmission oil temperature. This sensor is wired in series with the transmission
Park/Neutral switch. The Transmission Control Module (TCM) expects to see a valid voltage level
from the sensor when the shifter is in Reverse or any forward Drive position. The TCM also expects
to see an open circuit condition when the shifter is in the Park or Neutral position. When the controller
detects an open circuit when in Reverse or any forward drive position the DTC will set. Note: Due to
an open circuit condition in Park or Neutral, the TCM substitutes the Transmission Temperature
reading with Engine Temperature when in Park or Neutral.
Validation:
Check the transmission temperature sensor circuit. If the transmission temperature sensor sees any
stray voltage on it (other than 5 volts) when in park or neutral, the vehicle will not start. Unplug the
valve body and monitor the temperature circuit for a change. If voltage does not go high, open circuit,
track the circuit for shorts. With the park neutral open and no other vehicle issues the vehicle should
crank and start while disconnected.
JeepCares is online now
post #9 of 18 Old 01-27-2012, 02:25 PM
t3kmitch
2005 WK
The last time you started it it turned off on its own or you turned it off and couldn't get it started again?
-Sold 3/13. Replaced by 2010 VW Jetta 2.5-
2005 WK 3.7L Laredo. RC 2", 265 70 17 Bridgestone Dueler Revo 2's. Class III OEM hitch added. Bilstein Struts. Monroe Load Levelers (58643).
Blue WK Club Member #32
t3kmitch is offline
post #10 of 18 Old 01-28-2012, 07:30 AM Thread Starter
Cinna
2007 WK
I turned it off, and it wouldn't start again.
Cinna is offline
post #11 of 18 Old 01-28-2012, 07:58 AM
tom58
is the engine turning at all?
tom58 is offline
post #12 of 18 Old 01-28-2012, 03:42 PM
t3kmitch
2005 WK
There could be corrosion in the terminal to the starter. Worth a try to just replace the connection for a couple $$. Mine I was able to just clean a little bit and it works fine but maybe yours has a lot of buildup inside; so even with a new starter (clean on the solenoid side) it can't put the current through.
t3kmitch is offline
post #13 of 18 Old 01-29-2012, 06:37 AM Thread Starter
Cinna
2007 WK
Nothing, I'm clueless what is going on. I had an accident in dec but I have had my truck for 2 weeks now. I told the shop to let me know I'd it's related to it.
Cinna is offline
post #14 of 18 Old 01-29-2012, 07:38 AM
tom58
if it doesn´t turn at all it seems to be an electrical problem.starter batt. and key batt. are o.k. i suppose. have you got 12volt on your starter? what does the cable look like ? what sort of voltage have you got on your batt when you turn the key? i would think it´s something simple but you´ll have to work your way through, step by step
tom58 is offline
post #15 of 18 Old 01-30-2012, 04:55 PM Thread Starter
Cinna
2007 WK
UPDATE: it was a broken wire from the starter 80 bucks to fix.
Cinna is offline
'08 WK Transmission Temp Question Grancher08 WK Grand Cherokee & XK Commander Forum 11 04-22-2014 02:57 PM
Transmission over temp - strange Azzx WK Grand Cherokee & XK Commander Forum 4 11-21-2011 05:56 AM
transmission over temp medic1casey WK Grand Cherokee & XK Commander Forum 1 09-14-2011 07:39 PM
07 GC Laredo -- Transmission over Temp jmadzula1 WK Grand Cherokee & XK Commander Forum 4 09-12-2011 09:09 AM
Transmission Over Temp bigdunz WK Grand Cherokee & XK Commander Forum 0 09-03-2009 07:15 AM
