Transmission Maintenance - JeepForum.com
post #1 of 6 Old 07-06-2012, 10:50 AM Thread Starter
destruck
2006 WK
Hi guys
I bought my jeep back in December '11. It only had 31k miles and was SUPER clean. I have no history on the car because it was a dealer trade in, but there is no modifications and it is 100% stock. Not even a tow package was ever installed.
I was reading the FAQ and other stuff and saw about the trans. Some pages recommend never touching it, while others say 100k miles. I am at around 53k now, and I put a lot of miles on the car but not harsh miles just because my work requires me to drive all over the county on a daily basis. The Jeep is giving me no issue's what so ever, but I would like to do this as preventative. Would there be any problems doing a simple filter and fluid change (no flush) at this point, and probably every 20k-30k miles there after? Can changing it too soon hurt anything?
It may sound weird, but I always ran manual cars, never an auto and never anything this new, so i have no idea. I do know automatics are super expensive to fix / replace.
This is a 06 Jeep Grand Cherokee Laredo with the 3.7l and W5A580 trans.
I can only find threads on older model Jeeps, so any input is appreciated.
Thanks!
destruck is offline
post #2 of 6 Old 07-06-2012, 12:01 PM
colinzj
2006 WK
Nope on both counts. Go for it.
You could do a fluid and filter change with every oil change and not hurt anything other than your wallet.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L — Dead, sold, and rolling again
colinzj is offline
post #3 of 6 Old 07-09-2012, 09:21 AM
jstand22
Agreed. As long as you set a regular interval you can change it whenever. I changed mine at 60K (pretty sure that was the first time), and I'm about to do it again (it's got 105,000 now).
The reason you see people saying not to touch it is because if you let it go too far without changing it at all the material from the clutches wears off and remains in the fluid, so now the transmission is depending on the clutch matieral in the fluid because there's none left on the clutches. So if you change it, you might be in for real trouble. If the fluid is grey/silvery then it is saturated with the clutch material (it will smell horrible too, way worse than already horrible smelling ATF4) and you should not change it. If it's red/purple/kind of dark, you're alright.
So in your case, you're good to go...just don't wear a shirt you like when you do it.
jstand22 is offline
post #4 of 6 Old 07-09-2012, 10:48 AM
paroxysym
2007 WK
maintenance guy of mine told me to change the fluid in these things every 15k.. so every 15k i do a drain and fill, being as im coming up on a 30k interval ill be changing the filters when i do a drain and fill this time.
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #5 of 6 Old 07-11-2012, 05:40 PM
00RedWJ
2006 WK
15k For trans fluid is excessive unless you're towing or off roading a lot
2000 Red Laredo WJ
4.0 with Selec-trac - Sold
2006 Black Laredo WK
3.7 with 95,000 Miles
00RedWJ is offline
post #6 of 6 Old 07-11-2012, 07:07 PM
paroxysym
2007 WK
Meh he said if I want to save or make the tranny last change it every 15k. I don't take it to him for this so I don't see why he would tell me that if he's not profiting from it....
OEM+
05 5.7 maintenance boosst WK Grand Cherokee & XK Commander Forum 1 02-04-2012 10:00 PM
06 WK 60k maintenance? jm020 WK Grand Cherokee & XK Commander Forum 12 02-20-2010 06:08 AM
Oil Changes – DIY Maintenance Indian WK Grand Cherokee & XK Commander Forum 14 11-09-2009 09:11 PM
General transmission maintenance questions ?? melk ZJ Grand Cherokee Forum 2 09-22-2009 02:14 AM
i need all the maintenance help available... Derek33 ZJ Grand Cherokee Forum 2 06-18-2004 11:55 AM
