Transmission leak coming from around the fill tube - JeepForum.com
post #1 of 3 Old 11-11-2015, 07:38 PM Thread Starter
r_unda
My 2007 WK CRD with W5A580 transmission is leaking. The leak is coming from around the fill tube where it meets the transmission. Anyone knows the part number for the grommet or seal that goes in there?
Thanks
My Jeep isn't getting older, it's getting newer part by part
2011 WK2 HEMI 4x4 Overland
2007 WK CRD 4x4 Limited GDE Tuned
1998 TJ SE
1973 CJ5 - YJ OME 2.5" lift, 33" tires
1951 Willys truck
r_unda is offline
post #2 of 3 Old 11-12-2015, 06:27 AM
Nejeep
Jeep has a TSB to fix fill tube leaks on some early Nag1 transmissions like yours. It just calls for RTV around the tube seal (but no reference to seal number). Here is a link to the TSB, if that helps.
http://www.wkjeeps.com/TSB/tsb_wk_2101105a.pdf
Are you sure its the fill tube leaking or could it be the electrical connector next to it? I had to replace the connector on my Nag1 due to it leaking ATF.
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline
post #3 of 3 Old 11-12-2015, 07:46 AM Thread Starter
r_unda
Ok thank you. I will try the RTV
r_unda is offline
