Transmission help!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Transmission help!!!
2014 Spartan Locker Special - While Supplies Last! Dana 3OPTIC ARMOR WINDOWS all sale now !!!!!!!!Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits
Unread 04-09-2014, 04:10 PM   #1
94jeepman
Jager93
94jeepman's Avatar
2005 WK
throwing a bunch of codes and cant get the jeep to move unless its floored. stays in 3rd gear.
P0700, p0868, p0740, p0732, p1790, p0944, p0736, p0876
KHAKI MEMBER #59
The WK mods: SC flashpaq 3870, flow master super 40, 3.5" X Factor leveling kit, 33" M/T baja claws, 17" pro comp wheels, one 12 inch subwoofer, rugged ridge tailight gaurds, rola rack with 18" extension
94jeepman is offline   Reply With Quote
Unread 04-09-2014, 05:00 PM   #2
yzjwk
2005 WK
It's in limp mode . Erase the codes either with a scanner , or battery cable.
See if they come back . Could be a badly Split filter .
Proud owner : 05 WK Ltd 5.7 HEMI
90 YJ Islander 4.2 Cam'd & Decked
94 ZJ Ltd 5.2
00 WJ 4.0
yzjwk is offline   Reply With Quote
Unread 04-09-2014, 05:45 PM   #3
94jeepman
Jager93
94jeepman's Avatar
2005 WK
I erased the codes still doing it. Now my reverse is drive my neutral is drive and drive still stays in 3rd gear
KHAKI MEMBER #59
Unread 04-09-2014, 06:24 PM   #4
modernblueWK
Double check the mechanical shift linkage.
2008 wk 4.7 v8 Laredo X QTII - 245/70-17 at2 - Magnflow 13742
Blue WK club #4
2013 HEMI Durango Awd Crew. All stock
modernblueWK is offline   Reply With Quote
Unread 04-09-2014, 07:46 PM   #5
yzjwk
2005 WK
P0740–TCC OUT OF RANGE
P0868-LINE PRESSURE LOW
P0732-GEAR RATIO ERROR IN 2ND
P1790-FAULT IMMEDIATELY AFTER SHIFT
P0944-LOSS OF HYDRAULIC PUMP PRIME
P0736-GEAR RATIO ERROR IN REVERSE
P0876-UD PRESSURE SWITCH RATIONALITY
It looks like something might have gone in the transmission to loose prime & pressure , unless you have little to no fluid .I guess the shift mechanism or PCM/TCM module could cause the issue , but if the connections are good/clean , I would be dropping the pan myself and checking the filters .
94 ZJ Ltd 5.2
00 WJ 4.0
Unread 04-09-2014, 10:12 PM   #6
94jeepman
Jager93
94jeepman's Avatar
2005 WK
Filters just went in around 8000 miles ago. So that was going to be my last option to check. But you never know
KHAKI MEMBER #59
Unread 04-10-2014, 05:47 AM   #7
caulk04
2008 WK
Could be a split filter or a blown accumulator plate. Maybe something else, but the pan must come off to check for either of those things.
Limp mode should allow R 2 and 3, user selectable with the shifter. If the accumulator plate is blown though, that puts a whole 'nother wrench into that.
Tint, Superchips, SRT intake tube, Gibson catback, catch can. One hardcore DD/kid hauler...yeah.
caulk04 is offline   Reply With Quote
Unread 04-10-2014, 06:26 AM   #8
94jeepman
Jager93
94jeepman's Avatar
2005 WK
I'll have to dig into it when I have time. I need it fixed ASAP but have a bunch of other stuff going on now so I don't know what to do at the moment. Would a split filter make it throw 8 codes?
KHAKI MEMBER #59
Unread 04-10-2014, 06:44 AM   #9
kris06
2006 WK
Split filter and if there was no pressure your clutches went bad to due to no pressure
kris06 is offline   Reply With Quote
Unread 04-10-2014, 10:43 PM   #10
94jeepman
Jager93
94jeepman's Avatar
2005 WK
Could it be a split filter if I'm going forward in reverse and neutral tho?
KHAKI MEMBER #59
Unread 04-12-2014, 06:09 PM   #11
kris06
2006 WK
Is it in a limp mode?
Unread 04-12-2014, 09:57 PM   #12
94jeepman
Jager93
94jeepman's Avatar
2005 WK
How do you check that?
KHAKI MEMBER #59
Unread 04-13-2014, 07:32 AM   #13
kris06
2006 WK
Does it get stuck on third gear ?
Unread 04-13-2014, 08:08 AM   #14
94jeepman
Jager93
94jeepman's Avatar
2005 WK
Yes
KHAKI MEMBER #59
Unread 04-13-2014, 03:05 PM   #15
kris06
2006 WK
Then its in a limp mode you will need to rebuild
