Transmission Fluid change, Dealer screwing with me? - Page 4 - JeepForum.com
post #46 of 57 Old 03-17-2017, 12:48 PM
0WallyWest0
Originally Posted by oilverland View Post
Indeed there is no dipstick, nor can you get one. I tried.
Maybe not from a dealer, but you can order one from any parts outfit.
http://www.partsgeek.com/catalog/200..._dipstick.html
That's an aftermarket version, the "real" Mopar part is like $60, but those can be purchased as well.
You just have to use a scan tool to get the temperature of the fluid and match that up to the range on the dipstick.
0WallyWest0 is offline
post #47 of 57 Old 03-17-2017, 12:58 PM
ruskiybro
2005 WK
ATF+4 is what is on my 05 4.7 WK. Takes 8 or 9 quartz. Special fluid/transmission is bs. DO NOT FLUSH. Especially if you are high mileage, if you flush you will kill your trans. Im draining mine next weekend, and also changing both filters. Kolak priced a Wix kit (2 filters + gasket) for $30. Dealer said 75 per filter. Only go to dealership for warranty.
2005 4.7L WK / 2.25 OME / 32" BFG / Performance mods and fun stuff!
ruskiybro is offline
post #48 of 57 Old 03-17-2017, 04:47 PM
90grandoneer
90grandoneer's Avatar
2006 WK
If you plan on keeping it forever like I do, invest about $30 or less (shop around) for a pan with a drain plug in it. It takes a Dorman 265-817. Life will be much easier and cleaner next time.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
post #49 of 57 Old 03-17-2017, 05:07 PM
90grandoneer
2006 WK
Originally Posted by Raffish View Post
I'll be changing my tranny fluid and filters shortly...
If you're keeping it for a while, also get a pan with a drain plug (Dorman 265-817) for $30 or <. I also did a Transgo shift kit (under $50) last time I serviced mine. I've had the Sonnax Line Pressure Booster (around $50) on mine since I did my first fluid/filter change years ago. IMO, all of these are well worth the $$$ and help improve the transmission shift quality. Add custom shift schedules/torque management settings with the Superchips Tuner with the Advanced Transmission Tuning Application (ATT) and you've got this tranny about as good as it can get without a performance rebuild.
post #50 of 57 Old 03-19-2017, 09:25 PM
Raffish
2005 WK
..hhmm That could be beyond my in-experience, definitely beyond the wallet at the moment... I just noticed my harmonic balancer is wobbling a fair bit and will be tackling that next...and it needs struts, prob shocks and springs too.. I've changed air filter, oil, plugs, wires, pcv, have a new egr, MAP, IAT, serpentine belt coming. I cleaned the TB, ran a can of seafoam and am looking at making a catch can..I want to pull the intake manifold and clean it, new gaskets are coming..
I just want to get it back to reliable before upgrades...
Raffish is offline
post #51 of 57 Old 03-21-2017, 10:01 AM
08rubie1
Cost me 190 bucks for them to pop my pan off replace the filter filler back up. I did this yesterday at a Jeep dealer that normally over charges for everything. called for 4 liters of fluid .9 hours of labor this is for the 3.0crd with nag1
08rubie1 is offline
post #52 of 57 Old 03-21-2017, 11:59 AM
Brit30-06
2008 WK
Hi.
Just out of interest may I ask what fluid they put in please?
Brit.
Brit30-06 is offline
post #53 of 57 Old Yesterday, 08:06 AM
08rubie1
Originally Posted by Brit30-06 View Post
Hi.
Brit.
Atf +4
Put like 200 miles of highway driving on it at 60degrees out side... with no load at 75mph 1.5 lvling kit 255/70/17 mtrs max trans temp i saw was 177f that normalized out to around 168-172 while cruising.
08rubie1 is offline
post #54 of 57 Old Yesterday, 08:25 AM
ROWlegend
Ah the good old Stealership! Preying on the innocent trying to conform to the warranty guidlines.
Wine em, dine em, pipeline em!
ROWlegend is offline
post #55 of 57 Old Yesterday, 11:53 AM
Brit30-06
2008 WK
Atf +4
Hi.
Thank you for replying. I did wonder if it would be ATF4. I still can't get my head around putting ATF4 in a German made Mercedes Transmission but it obviously works.
Brit.
post #56 of 57 Old Yesterday, 01:15 PM
08rubie1
Hi.
Brit.
from what i have read on the merc forum and sprinter forum dcx made some mods to the internals so it can be put in the srts and some of the jeeps.
08rubie1 is offline
post #57 of 57 Old Yesterday, 03:54 PM
underscore
2007 WK
What does the shift kit do? Is there an install guide on here?
2007 WK CRD QDII
underscore is offline
Transmission Fluid Change TonyVideo WK Grand Cherokee & XK Commander Forum 5 09-15-2009 01:29 PM
Transmission fluid change matt21484 ZJ Grand Cherokee Forum 21 07-27-2009 02:47 PM
ZJ Transmission Fluid Change HawgFlies ZJ Grand Cherokee Forum 3 03-16-2009 06:49 PM
How to change transmission fluid Hi Its Me Sami ZJ Grand Cherokee Forum 5 09-12-2007 11:00 AM
Can't change transmission fluid? Bloodbath ZJ Grand Cherokee Forum 27 12-19-2006 06:47 AM
