Transmission Fluid change, Dealer screwing with me? - Page 3 - JeepForum.com
 1Likes
post #31 of 59 Old 12-03-2011, 07:31 PM
t3kmitch
2005 WK
I'm pretty sure they don't recommend flushing. It can stir up junk and just cause problems. I think most people just drop the pan and change the filters and whatever fluid they can. I'll get around to mine one of these days.
-Sold 3/13. Replaced by 2010 VW Jetta 2.5-
2005 WK 3.7L Laredo. RC 2", 265 70 17 Bridgestone Dueler Revo 2's. Class III OEM hitch added. Bilstein Struts. Monroe Load Levelers (58643).
Blue WK Club Member #32
t3kmitch is offline
post #32 of 59 Old 12-04-2011, 05:58 PM
donDavide
2007 WK
Please Advise
Originally Posted by donDavide View Post
OK,
I have a statement and a few questions, I have the 545RFE with the 3.0 CRD, but mine has NO DIPSTICK!!! Just a plastic cap/cover that says service only by Mercedes. I bought my ATF+4 (full synth Valvoline) from NAPA and they said 6.1 qts. The shop I went looked up and it said 13qts. What do I do? Without a dipstick? My statment is that my tranny has a drain plug!!! It is 5mm hex. As for the diffs they had Valvoline 75-140 full syn and I had to by friction modifiers.
Oh, one more question. Does anybody know exactly where the transmission range sensor is exactly? I get an intermintant code 0705 when the tranny won't shif out of first on occasion. I have read here that the sensor should be clean before possibly wasting money on he one.
I could really use some advise. Thanks.
donDavide is offline
post #33 of 59 Old 12-04-2011, 07:52 PM
oilverland
2008 WK
OK,
If you have the 545RFE then it's a custom build! The CRD uses the "NAG1; W5J400 - W5A330; 5-Speed; Automatic Transmission" not the 545RFE. See the parts manual at http://www.wkjeeps.com/wk_brochures.htm#MANUALS. One giveaway is that CRDs don't have tow mode, if for no other reason than the W5J400 - or is it called the W5A300, I can't tell - doesn't have two 2nd gears (tow mode uses both). But then, it doesn't need it.
Indeed there is no dipstick, nor can you get one. I tried. The parts guy at the Jeep dealer has a Mercedes and he can't get one for his car either. He tells me some electronic device (he knew the name but I forget it) is attached somewhere to check the fluid level. So I am resigned to having somebody do xmission fluid changes for me. I'll be looking for an independent Mercedes specialist to hopefully save some money and yet get it done correctly.
Sorry I don't know what the transmission range sensor is, much less where it is. Does it sense power lines?
2008 Overland Diesel QDII, Bilsteins, Stillen rotors and pads, 156,000 miles as of Nov '16.
oilverland is offline
post #34 of 59 Old 12-05-2011, 08:44 AM
Jeep Brian
Flushing the trans is not with a chemical! It is more like bleeding the brakes... They pump new fluid in to the trans and they watch the color of the fluid leaving the trans. When the fluid coming out is the same color as the fluid going in, they stop. That's what is meant by a flush.
Mine: 07 GC Limited Hemi stock for now.
Hers: 14 Dodge Durango Citadel Hemi
68 Firebird 350 4 spd #'s matching
Jeep Brian is offline
post #35 of 59 Old 12-05-2011, 09:00 AM
colinzj
2006 WK
Not always true. Many shops, including dealers, do use a "transmission cleaner" solvent from the likes of BG (who of course claims it cures all that ails you and that the transmission is full of filth that needs to be cleaned out with their product).
Don't assume. Ask.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L ó Dead, sold, and rolling again
colinzj is offline
post #36 of 59 Old 12-05-2011, 12:01 PM
ianrmz250
2007 WK
Indeed you should have the W5J400 trans fitted to your CRD.
Trans level has to be measured when at a certain temperature , on the W5J400 the correct level is 68mm when fluid temp is 140 degrees F.You will need some means of measuring the temp correctly when the engine is running and the gear selector is moved through Drive/ Reverse /Park several times ,i use a Dashhawk and when temp reaches 140 F i check the level with a long welding rod and measure the amount of oil on the end of the rod with a engineers rule.
I have changed my fluid and filter several times using this method with no issues.
ianrmz250 is offline
post #37 of 59 Old 12-05-2011, 08:08 PM
donDavide
2007 WK
Well you learn something new everyday, I did research and thats why I thought is was the same. tranny. Speed range sensor, comes up on the P0705 code. Thanks.
post #38 of 59 Old 12-06-2011, 06:21 AM
donDavide
2007 WK
I also read w5a580. Confusing. I should have gotten a Toureg TDi, LOL. I know VWs.
post #39 of 59 Old 12-07-2011, 08:48 AM
modette
2005 WK
My dealer said not to flush, I checked the dipstick and it was bright red still so I am thinking it was done. I'm waiting till next spring as it looks like a mess to do (still deciding if I will weld a bung in the pan or buy the nicer heavy duty pan)...I'm leaning towards buying the heavy duty one.
Reason being with a bung welded in, the pan is not made to drain the fluid, so their be a ridge inside, thus not all the fluid or the junk that might settle get drained.
modette is offline
post #40 of 59 Old 03-13-2013, 11:44 PM
silentknight
1967 CJ5
ive got a 05 4.7 QD2 JGC, which im hoping to do the trans fluid change. Does anyone know if the trans filter is a deep pan or shallowpan type? im buying from Rock Auto & it shows 2 types? =/
Sorry sonny,..that Jeeps gonna take a bit more than some buffing to fix!
build in progress -> 67' CJ5, stretched 110" WB, widened 5" /ISUZU C240/TF727/NP203/D300/D44HD & D60 from a 74' IHC 200/38.5 GROUND HAWGS/10X15 DIY BANDED STEELS
silentknight is offline
post #41 of 59 Old 03-14-2013, 08:16 AM
JRLT
2010 WK
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #42 of 59 Old 03-14-2013, 09:18 PM
bmuhlbach
There is 2 filters one is like a oil filter the other is a regular style no gasket there rtved on.I bought mine from the dealer give them the vin no. and got the right parts
bmuhlbach is offline
post #43 of 59 Old 03-17-2017, 11:59 AM
Raffish
2005 WK
I'll be changing my tranny fluid and filters shortly...
Raffish is offline
post #44 of 59 Old 03-17-2017, 12:01 PM
Raffish
2005 WK
Raffish is offline
post #45 of 59 Old 03-17-2017, 12:39 PM
wave_crusher
2006 WK
Tranny fluild and fliter change is very easy in my WK. I read the OP post and was like "Wtf?, i'd love for a dealer to tell me that. I'd be like is my 545RFE made out of titanium?"
06 4.7L QT-II, RC 2", 255/70-17 Revo2, 1.5 spacers, SC Tuner, coilover shocks
Blk WK member #174
wave_crusher is offline
Transmission Fluid Change TonyVideo WK Grand Cherokee & XK Commander Forum 5 09-15-2009 01:29 PM
Transmission fluid change matt21484 ZJ Grand Cherokee Forum 21 07-27-2009 02:47 PM
ZJ Transmission Fluid Change HawgFlies ZJ Grand Cherokee Forum 3 03-16-2009 06:49 PM
How to change transmission fluid Hi Its Me Sami ZJ Grand Cherokee Forum 5 09-12-2007 11:00 AM
Can't change transmission fluid? Bloodbath ZJ Grand Cherokee Forum 27 12-19-2006 06:47 AM
