Transmission cooler on 07 WK - JeepForum.com
post #1 of 11 Old 07-01-2008, 07:39 PM Thread Starter
dalefan4lyf
2007 WK
Anybody have any ideas on how I can add an auxillary transmission cooler to a 2007 WK? I am looking at getting a camper and I thing I am gonna need the extra cooling for the transmission. Also, my WK did not come with a towing package so I installed the factory hitch and trim bezel to get me through. Anybody know what else came with the factory tow package? THANKS IN ADVANCE!!!
dalefan4lyf is offline
post #2 of 11 Old 07-01-2008, 08:34 PM
airportdave
2010 WK
I'm not sure about adding a tranny cooler- but I wouldn't think it would be too hard. Factory tow packages varied by engine size- check out this link:
http://www.wkjeeps.com/wk_towing.htm.
2010 Grand Cherokee Limited Hemi Q-D II, OME MD, 265/70/17 Hankook ATM's, HemiFever Tune
airportdave is offline
post #3 of 11 Old 07-02-2008, 03:32 AM
tednelson83
i mounted mine between the stock cooler, and the power steering cooler. worked out well. i have pics if you want but there kind of crappy.
Sacramento Alumni. ASE A6, A8, and L1 Certified. CA Smog License.
1993 Jeep Grand Cherokee Limited 5.2 4x4, IRO 3.5" lift, Spidertrax adapters, 32" BFG M/T's on 17" cragar soft 8's, Flowmaster muffler.
1987 Pontiac Fiero GT 2.8
Liberalism stems from the notion that it's entirely possible to pick up a turd by the clean end.
tednelson83 is offline
post #4 of 11 Old 07-02-2008, 02:31 PM
stgry1
2006 WK
hmmm I thought they all came with one?? My 06 base O grande Laredo came with it
db
Brandon, FL
USMC
06 Silver Laredo
mopar bug shield, rear mopar air deflector, K&N drop in w/ modified OEM air intake, 08 Gladiator wheels w/ 255/60/18s.
stgry1 is offline
post #5 of 11 Old 07-02-2008, 05:43 PM Thread Starter
dalefan4lyf
2007 WK
I would love to see pics if you have them. Crappy or not. Thanks!!
post #6 of 11 Old 07-02-2008, 06:35 PM
stgry1
2006 WK
Sure..raining here like usual (Fl), when it stops I'll snap a few. I'm guessing it's a trans cooler.I suppose it could be an oil cooler but I find that a bit odd. I'll actually look at it and follow the lines to be certain.
db
Brandon, FL
USMC
06 Silver Laredo
stgry1 is offline
post #7 of 11 Old 07-03-2008, 04:38 AM
tednelson83
this picture shows where i installed my aux tranny cooler. it is placed between the stock tranny cooler that is integrated with the a/c condenser, and the long skinny power steering cooler. i have it plumbed so that the fluid flows first to the stock cooler, and than to the auxiliary cooler.
post #8 of 11 Old 07-03-2008, 04:39 AM
tednelson83
post #9 of 11 Old 07-03-2008, 03:40 PM
jeepgaffer
2006 WK
Originally Posted by tednelson83 View Post
....i have pics if you want but there kind of crappy.
You weren't kidding!
BTW, what auxiliary trans cooler did you use, and where did you get it? Also, how hard was the install?
2006 Bright Silver Grand Cherokee Laredo
3.7L 4WD ("mostly" stock)
jeepgaffer is offline
post #10 of 11 Old 07-03-2008, 07:45 PM Thread Starter
dalefan4lyf
2007 WK
THANKS Ted. Crappy pics confirmed, but, VERY helpful! Could you tell me size and how and what you mounted it too. Thanks my friend.
post #11 of 11 Old 07-04-2008, 03:31 PM
waterboiler
There are multipe sizes of coolers available at most auto parts stores. Fairly easy to install, once you find a spot to mount it. The more/cooler the air flow it gets the better but put a big one in front of your rad/condenser and you could have other problems due to air flow.
If this is only for "backup" consider going with one of the smaller units - the ones like mini rads ( fins ) do a better job. Before going with the smaller unit be sure you have the stock cooler, it should be at either the top or bottom of the condenser.
waterboiler is offline
Get by without Transmission Cooler??? Nburns24 ZJ Grand Cherokee Forum 22 04-29-2009 12:53 PM
Transmission cooler fisher1630 ZJ Grand Cherokee Forum 13 02-25-2008 05:29 PM
Transmission Cooler bill9000 ZJ Grand Cherokee Forum 1 07-17-2006 11:05 PM
Transmission cooler? DuneCrawler ZJ Grand Cherokee Forum 2 06-20-2004 10:43 PM
Transmission cooler baseball_coach WJ Grand Cherokee Forum 1 01-20-2004 01:58 PM
