Trailer Wiring: Starscan? - Page 2 - JeepForum.com
post #16 of 19 Old 06-26-2009, 02:07 AM
DarrylFlynn
2006 WK
Originally Posted by merlinTec View Post
Hi
never had to do it for our UK kits itís just plug and play. Regards,
Merlin
I can confirm that i fitted my own Towbar but used the Jeep wiring harness electrics kit and it was indeed Plug and Play on my UK Overland. No dealer visit required.
Regards Darryl
DarrylFlynn is offline
post #17 of 19 Old 06-26-2009, 01:39 PM
conrasm
conrasm's Avatar
I had the hitch and factory wiring installed at the dealer. I haven't actually hooked up the trailer yet, but the 7 to 4 pin adapter has the small LEDs and they lit up with the brakes and parking lights, so hopefully that will be functional when we take the boat this weekend.
I don't think I'll ever need it, but what is involved in adding a brake controller. I know my Ram already had the harness under the dash and all I did was plug the wire harness into the controller and factory plug.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #18 of 19 Old 06-27-2009, 07:44 AM
nostaw22
There are 4 wires to connect. Jeep only provides 1 of them, but it would be a PITA to run.
There is a green wire under the dash (not connected) to the controller (it connects the signal to the brake pin on the 7-pin connector), run wires to/from the battery (+ and - terminals), and connect to the brake actuator switch under the dash.
All the info is here at wkjeeps.com.
JW
1998 XJ - built for offroading
2007 WK CRD - DashHawk, for towing the XJ
nostaw22 is offline
post #19 of 19 Old 06-27-2009, 07:58 AM
Laloggia
2010 JK Wrangler
The brake controller wasn't hard to install, more time consuming. Took me about 2 hours. The one i purchased has 4 wires - battery power, ground, green brake pedal wire, and one wire i had to run to the back trailer wire harness on vehicle side (blue wire). Thats it. I didn't even check to see if the Jeep was pre-wired or not for this, but it works...
Were taking it camping this weekend, hopefully it won't act up.
2010 Wrangler Islander
2005 Chrysler Crossfire
2010 Honda Crosstour
2007 Honda Civic Coupe
Laloggia is offline
Trailer Wiring f-series ZJ Grand Cherokee Forum 9 01-21-2010 08:54 AM
Trailer wiring help f-series ZJ Grand Cherokee Forum 2 01-17-2010 08:39 AM
HELP!!!!!!!!!!! Trailer Wiring W2001J ZJ Grand Cherokee Forum 10 08-21-2009 12:06 AM
Trailer Wiring Fugative ZJ Grand Cherokee Forum 3 03-30-2006 05:26 PM
Trailer wiring help ostroffd ZJ Grand Cherokee Forum 2 01-06-2005 09:27 AM
