Trailer Wiring: Starscan? - JeepForum.com
post #1 of 19 Old 03-08-2008, 03:40 PM Thread Starter
mkuzmukerau
mkuzmukerau's Avatar
Do you NEED to have the starscan hooked up if you add the hitch/wiring yourself? Can anyone else do it, ie Autozone? Advanced?
2005 LJ Rubicon w/Savvy 4" and 35's
2009 XK Limited
2008 JK Unlimited Rubicon - Sold
2007 XK Rocky Mtn 4x4 - Totalled
2004 TJ X - Sold
mkuzmukerau is offline
post #2 of 19 Old 03-09-2008, 10:42 AM
ItalianJeeper77
2015 KL Cherokee
Im interested in this too, since I will do that this spring.
-MIKE
1996 ZJ *Sold | 2000 WJ *Sold | 2005 WK *Sold | 2008 WK *Sold
2015 KL
ItalianJeeper77 is offline
post #3 of 19 Old 03-09-2008, 11:39 AM
PropDr
2006 WK
If your Jeep came with the tow package it has relays for the trailer wiring and needs no further StarScan set-up.
06 WK 5.7, No Badges,Gibson CatBack, BWoody CAI, Eibach Springs & upper Ball Joints; F/R ADDCO Bars w/BWoody links; SRT8 Bilsteins; SRT8 Wheels w/ F: 275/50/20, R: 305/20/45 Tires; Passport SRX; 6 Bosch HID's; SRT8 Engine Covers w/ 5.7L badge: Kicker Sys.
PropDr is offline
post #4 of 19 Old 03-09-2008, 12:09 PM
z_gilligan
2010 JK Wrangler
Yes you need to bring it to a dealer and they have to activate the package. Only takes 10 minutes or so.
I got charged 40 bucks for that HARD and labor intensive work
z_gilligan is offline
post #5 of 19 Old 03-09-2008, 12:43 PM
PropDr
2006 WK
Gilligan, you are confusing me
If you have the tow package there will be relays installed that remove the trailer wiring from the can bus system.
I installed my trailer brakes and everything is working perfectly without paying the dealer.
PropDr is offline
post #6 of 19 Old 03-09-2008, 02:50 PM
ItalianJeeper77
2015 KL Cherokee
what if your GC did not come with a tow package or anything, i do not even have the cutout in the bumper.... i found out how to do that much! haha
--MIKE
2015 KL
post #7 of 19 Old 03-09-2008, 02:51 PM
merlinTec
merlinTec's Avatar
Hi
There is an option on star scan to turn on trailer tow relays (see my list of star scan options)
http://www.jeepforum.com/forum/f67/list-starscan-items-could-activated-520079/ but never had to do it for our UK kits it’s just plug and play.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #8 of 19 Old 03-09-2008, 03:24 PM
z_gilligan
2010 JK Wrangler
This is the question I responded to... If you ADD the hitch and harness onto your Jeep as an aftermarket item then yes you have to get it activated; if it was already on there when you bought it you do not.
ItalianJeeper77...
I went with these guys to get the hitch, bezel, and the harness... A Lot cheaper than straight from MOPAR
http://www.wyckoffchryslerparts.com/exac7.html
post #9 of 19 Old 03-09-2008, 04:01 PM
PropDr
2006 WK
I stand corrected.
My mind was on the post about the trailer brake controller installation.
PropDr is offline
post #10 of 19 Old 06-11-2009, 07:45 PM
Laloggia
2010 JK Wrangler
What happens if you buy a standard 4 wire trailer harness and splice it into the taillights? Will it work without having to get it scanned from the stealership?
This would bypass any relays and would work off the lights and signals...the question is....do the lights and signals notice the voltage draw and start to act up...blink fast, etc.
Anyone?
2010 Wrangler Islander
2005 Chrysler Crossfire
2010 Honda Crosstour
2007 Honda Civic Coupe
Laloggia is offline
post #11 of 19 Old 06-12-2009, 03:28 PM
merlinTec
merlinTec's Avatar
yes it should act up but not tried it.
post #12 of 19 Old 06-12-2009, 09:30 PM
robpp
they have harnesses now that plug into your tail lights. well not into, you unplug the tail lights, you put this plug in between the light and the original plug. i found some on ebay like that.
Rob 007 Laredo 4.7 FFV 27X; DeBadg'd; Zaino'd; SRT8 Grill, Pedals, Strut; ClearBra; WeatherTech; LED Reverse; HIR Hi/Lo; SS Fog; Stealth Turns; 15% Tint; Stubbie; Rear Spoiler; Magnaflow; V1; 22Elite Console/Visors; Body Kit; Color Match Everything; TintedTails; K&N 63; Front Skid; QuickOilDrainValve; BatteryTender; SuperChips 91; Bilstein; Billet Window Switches; Greasable Addco Sways; RamMedic Hood; Fastman TB; BWoody Links; Kicker Upgrade w/Single Sub; AVIC F90BT Hacked; NeffyWrap ABCD; Putco LEDs; Viper 20s w/255/50; R1 Slot/Dimple w/Hawk Pro Ceramic; Whistler Mod w/FlashTech Halos
robpp is offline
post #13 of 19 Old 06-12-2009, 09:47 PM
Laloggia
2010 JK Wrangler
I just purchased the harness off of JCWhitney for $55.00 that plugs into the taillights. Let you all know if it works without getting it re-programmed by dealership. Fingers crossed.
Laloggia is offline
post #14 of 19 Old 06-25-2009, 02:22 PM
Laloggia
2010 JK Wrangler
Update:
I received the Wire harness from JC Whitney (made by Curt) and plugged it into the taillights. I then installed my brake controller and wired it all up to a 7 pin connector for our small pop-up camper.
Plugged her in and had brake lights, turn signals, lights....the works...NO STARSCAN TOOL Required....im so happy. Everything works great!
Laloggia is offline
post #15 of 19 Old 06-25-2009, 02:38 PM
mwking
2007 WK
I had one of the harnesses that plugged into the the tail lights when I had the 4 wire hookup. It worked fine most of the time, but it did make the Jeep think a turn signal bulb was out frequently. It was a pain because the signals would start blinking so fast that no one would be able to tell you were signaling a turn. It would only be the signals for one direction. I figured out if I turned the hazard flashers on, even just for one blink that it would reset and blink the turn signals at normal speed. I now have the 7 wire factory harness and I had to have the dealer activate the relays with Starscan to get the turn signals to work, but it has worked perfectly.
mwking is offline
Trailer Wiring f-series ZJ Grand Cherokee Forum 9 01-21-2010 08:54 AM
Trailer wiring help f-series ZJ Grand Cherokee Forum 2 01-17-2010 08:39 AM
HELP!!!!!!!!!!! Trailer Wiring W2001J ZJ Grand Cherokee Forum 10 08-21-2009 12:06 AM
Trailer Wiring Fugative ZJ Grand Cherokee Forum 3 03-30-2006 05:26 PM
Trailer wiring help ostroffd ZJ Grand Cherokee Forum 2 01-06-2005 09:27 AM
