Trailer hitch mod - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Trailer hitch mod
All Bilstein shocks & struts - Lowest Prices Ever and Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!
Unread 11-21-2014, 03:37 PM   #1
Brains72
2007 WK
Trailer hitch mod
Just got my new 265/70/17 tires and got a used one to put under for the spare. I know I need to mod the hitch and I saw some that used carriage bolts as a replacement and then cut down the receiver tube.
Is this ok if I plan on using the hitch to tow a 5k lb trailer with a weight dist hitch
Do they make grade 8 carriage bolts?
Thanks in advance
Ed
Brains72 is offline   Reply With Quote Quick reply to this message
Unread 11-21-2014, 03:39 PM   #2
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
My hitch is cut back (modded) and I've towed many times with the load you are looking to pull.
It's fine.
~Mike~
My Build Thread WK
My Other Build Thread XJ
'01 XJ with some stuff
Sept 2013 Cherokee of the Month
'07 WK with some other stuff
~RED WK CLUB #7~
'11 KK with mostly stock stuff
'06WK our first Jeep with stock stuff - totalled and gone
JeepN4KC is offline   Reply With Quote Quick reply to this message
Unread 11-21-2014, 04:18 PM   #3
Brains72
2007 WK
Thanks
Unread 11-21-2014, 04:18 PM   #4
luckyse7ens
2010 XK Commander
Yup The Bison build has been done this way.
http://www.jeepforum.com/forum/f67/o...l#post12793004
Black WK Club #152
luckyse7ens is offline   Reply With Quote Quick reply to this message
Unread 11-21-2014, 08:32 PM   #5
TangoTango
2008 WK
Carrage bolts are not graded, no way would I use them. Better to cut off the bolts and the hitch.
I just did the mod and it is easiest if you remove the bumper.. and the hitch .. cut the hitch and put it back. You have to buy 4 for those pop revets.
Towed a boat down south.. 6 hour drive on the new 265-70-17. Mileage dropped to 11 mpg running hard and fast.
Black WK Club #147
Life is hard. ...- John Wayne
TangoTango is online now   Reply With Quote Quick reply to this message
Unread 11-21-2014, 11:22 PM   #6
Chirpz
Chirpz's Avatar
2007 WK
Ditto.... NO carriage bolts..... ever, on a hitch or anything that requires strength. Bolts must be hardened steel..... grade 8. I had a hitch break once this very reason.... fortunately it fell off just as I pulled up to a stop sign.... sort of a miracle really. And the stop sign was next to a hardware store. That's when I learned about hitches and grade 8 bolts.
Chirpz
2007 WK 3.0L CRD, Quadradrive II, GDE EcoTune, DPF-Delete
4xGuard Front, Rear, Belly, & Side Rails, Factory Skids
EHM MOD, Garmin Mechanic EcoHD, K&N Filter (Deleted)
Chirpz is offline   Reply With Quote Quick reply to this message
Unread 11-21-2014, 11:27 PM   #7
CavallinoRed
2006 WK
You may not be able to find grade 8 carriage bolts at Home Depot but they're easy to find online.
But does bring up a good point to use a quality bolt for this application.
CavallinoRed is offline   Reply With Quote Quick reply to this message
Unread 11-24-2014, 01:17 PM   #8
luckyse7ens
2010 XK Commander
I hadn't realized they were so difficult to find locally. I had seen them available online.
Black WK Club #152
Unread 11-24-2014, 05:52 PM   #9
TangoTango
2008 WK
the bolt number pictured above is 807A which is not graded, it is a zinc covered one.
anyways .. cutting them down works .. but then the rear 4xguard skid plate doesn't fit.
Black WK Club #147
Unread 03-05-2015, 01:33 PM   #10
jd0110
Junior Member
2007 WK
For those that have done this with the hitch on the vehicle, how tough was it? Was it just a matter of using an angle grinder? Appreciate everyone's insight. I've just now gotten my 265/70/17 spare and it absolutely won't fit with the hitch as it sits.
2007 CRD QDII, OME HD, JK AEV Pintlers, 265/70/17 BFG KO2, 4xGuard Matrix, GDE ECO
jd0110 is offline   Reply With Quote Quick reply to this message
Unread 03-05-2015, 07:12 PM   #11
jd0110
Junior Member
2007 WK
Well, my buddy convinced me to just use a reciprocating saw with a good metal blade. This worked great for the hitch while still mounted. I did get a little crooked, so started back in from the other side which left a bur that I needed to file down. So not as pretty as others, but certainly was effective. Next is to cut the bolts, but the blade I used for the hitch is seemingly dull now and isn't cutting the bolt so well. Tomorrow I plan to buy a new blade to finish the bolts. I'm still not certain this new 265/70 BFG is going to go in without some help after doing the bolts. I'll update soon...
Unread 03-09-2015, 06:40 AM   #12
jd0110
Junior Member
2007 WK
I was able to easily cut the bolts with the new blade. Wow, this is still a really tight fit. I got the spare in there, but not convinced it's seating 100%. The tire surely folds my wire harness over tight on the hitch, and it's now hitting on the heat shield. Definitely didn't fit as easily as I'd hoped from my research. Really appreciate all the insight from this thread as well others thus far as I couldn't have gotten this far with all my mods without them. Thanks!
