Trailer hitch help - JeepForum.com
post #1 of 9 Old 08-30-2011, 08:19 PM Thread Starter
cbioo
Trailer hitch help
I own a 2009 Grand Cherokee and I'm looking to have a trailer hitch installed. I went to my Jeep dealership today and inquired about the mopar hitch that is set into the bumper. Between the parts, electrical and labor they quoted me $1200 to install. Seems crazy expensive. I like the way the mopar hitch looks but don't want to spend that much money. Looking for any guidance on a good hitch and what i should expect to pay to have one installed. Thanks.
cbioo is offline
post #2 of 9 Old 08-30-2011, 08:23 PM
DuncsJeeps
DuncsJeeps's Avatar
2006 XK Commander
I am in a similar situation.... mine doesn't have a hitch.
From what I can tell all you need to do is to find a wrecked WK at a pick a part and pull the hitch, wire harness, etc and you can cut your bumber and just bolt it on.
...If someone knows better, please let me know.
DuncsJeeps is offline
post #3 of 9 Old 08-30-2011, 08:26 PM
2005GRANDONE
2005 WK
If your not worried about clearance and not going to do it yourself places like uhaul have aftermarket hitches that don't cut the bumper. And probably a lot cheaper
sent from my iPhone using jeep forum
05 laredo, 4.7 V8, H.O. cams, fastman t.b. OME hd 3", Rustys .5 spacers, bilstein 5150 rear, yukon spider & side gears, superchips flashpaq, 33x12.50x17 nitto mud grapplers on black moabs, 1.5 spidertrax wheel spacers, flowmaster 40 series, K&N cai, Mopar gas tank, T.C & engine skid plates, riddler diff cover, removed sway bar on front.
Jks quicker disconnects for sale pm me
2005GRANDONE is offline
post #4 of 9 Old 08-30-2011, 08:40 PM
sunrcr69
2005 WK
I installed a Mopar hitch on my jeep a few weeks ago, it cost me under $250 and about an hour of my time. looks great.
you need:
the proper wiring for your application (4 or 7 pin)
and
http://cgi.ebay.com/ebaymotors/2006-...item48405f1f4e
and
enough skill to cut the plastic bumper cover - a dremmel or die grinder works nice here
and
an oversized rivet gun or some ingenuity
2005 WK 5.7L Hemi, RC 2" BB + fabrication = 3.5" lift, JK Rubicon Tires & Wheels, 1.25" Spacers, Fabricated Skidplate, Fabricated Recovery Points, Airaid CAI, Superchips, HIDs RED WK Club #10
sunrcr69 is offline
post #5 of 9 Old 08-30-2011, 08:42 PM
JRLT
2010 WK
JRLT is offline
post #6 of 9 Old 08-30-2011, 11:09 PM
DarthJeep
2005 WK
I purchased and installed a Reese Class IV hitch. Hangs just under rear bumper. Rated at 5500lbs. towing and 500 dead weight. Cost about $120 online and took 15min, a socket wrench, torque wrench, and a case of beer.
Build Thread -
Black Wk Club 166
DarthJeep is offline
post #7 of 9 Old 08-31-2011, 02:17 PM
Nejeep
I also just installed a Class III Draw-tite hitch which comes out just below the bumper,so not cutting needd. Amazon has similar Curt hitches for about $85 shipped. Installation is a DIY if you have a 3/4 socket. Removing the two bumper push pins is the only slightly tricky part. The center of the push pin needs to be lifted about a 1/4" then the whole pin comes out without damage.
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline
post #8 of 9 Old 08-31-2011, 11:35 PM
Chirpz
Chirpz's Avatar
2007 WK
I HAD a 2000 GC and I ordered a class 4 hitch online. Can't remember where right now. I also ordered the plug and harness. I installed it myself in one afternoon and it worked GREAT. This hitch did require trimming the plastic bumper and it came with bumper trim so when it was done, it looked like a factory job. No drilling was necessary, simply a bolt on job.
This was in year 2008 and total cost was around $400.00
My current jeep is a 2007 WK CRD and it came with a hitch.
I highly recommend that you get a hitch that uses load levelers and a sway bar.
Chirpz
2007 WK 3.0L CRD, Quadradrive II, GDE EcoTune, DPF-Delete
4xGuard Front, Rear, Belly, & Side Rails, Factory Skids
EHM MOD, Garmin Mechanic EcoHD, K&N Filter (Deleted)
Chirpz is online now
post #9 of 9 Old 09-01-2011, 10:57 AM
IceMan24
2007 WK
I had a Class III Mopar hitch installed at a dealership, included the hitch, wiring harness, bezel to cover the cut in the bumper, and a nice rubber hitch cover with the Jeep logo on it. All totaled, with labor, was around $250. Sounds like you're getting hosed.
IceMan24 is offline
2009 , grand cherokee , mopar , trailer hitch
trailer hitch fishjeep1 ZJ Grand Cherokee Forum 1 10-24-2010 06:04 AM
is this a zj trailer hitch str8stock4l ZJ Grand Cherokee Forum 10 08-21-2009 05:29 PM
ZJ Trailer Hitch..... DothanJeep ZJ Grand Cherokee Forum 5 04-07-2009 09:38 PM
Trailer Hitch clemsongt ZJ Grand Cherokee Forum 5 11-06-2008 09:02 AM
Best trailer hitch for 97 ZJ 311unity13b ZJ Grand Cherokee Forum 5 03-30-2008 04:36 PM
