tps problems 07 3.7L - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > tps problems 07 3.7L
Dan's Old as Dirt Birthday Sale!Premium LED Lighting by VISION X, Proudly sold at ROCKRIDGGEARSHADE Pocket Tops in stock and available at ROCKRIDGE
Unread 07-03-2014, 08:41 AM   #1
koivu
2004 XJ Cherokee
could it be tps? jeep runs normal to the store ,shut off ,go in , restart and leave jeep wont rev past 2000rpm with accelerator to the floor, pull over turn off restart and runs perfect again, happens about every 5 starts
koivu is offline   Reply With Quote
Unread 07-03-2014, 10:36 AM   #2
jeepin_in_a_wk
2007 WK
Have any dtc's?
jeepin_in_a_wk is offline   Reply With Quote
Unread 07-03-2014, 12:03 PM   #3
koivu
2004 XJ Cherokee
No dtcs, also this is a grand cherokee
Unread 07-03-2014, 07:18 PM   #4
tom19511
2006 WK
search shifter module on this forum.
Tom19511
tchristopher1@wowway.com
2006 Grand Cherokee Laredo 3.7
2007 Liberty Sport 3.7
tom19511 is offline   Reply With Quote
Unread 07-03-2014, 07:49 PM   #5
Nejeep
I would expect the TPS sensor to throw a code if it were bad. Doubt the shifter module would prevent the engine from running over 2k rpm. Sounds more like a wiring problem somewhere, bad ground, shorted O2 sensor or wire, corroded battery connection, etc. Any recent work done on the engine that might have messed up wiring? Does the engine sound normal but just not rev more than 2k rpm or does it misfire and die? I believe 07 was the first year for drive-by-wire on the 3.7 engine.
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline   Reply With Quote
Unread 07-04-2014, 08:25 AM   #6
koivu
2004 XJ Cherokee
Engine runs totaly normal,no clue that anything is wrong except no acceleration
Unread 07-05-2014, 08:09 PM   #7
patconva
My 07 has done that 3-4 times over the last two years. I finally noticed that when it happens the little square on the shift indicator that indicates which gear you are in is lit on EVERY gear. The solution for me has been to turn off the car and restart it - has cleared it every time do far.
patconva is offline   Reply With Quote
Unread 07-06-2014, 05:24 PM   #8
rivisio
2005 WK
my jeep also does this, its a 2005 3.7L i also thought it would be tps sensors, been doing it for the last 2 weeks.
Only happens after engine goes above 3000 rpms. if i keep it under 3000 it wont get stuck at 2000rpms.
rivisio is offline   Reply With Quote
