TPMS Sensor - JeepForum.com
post #1 of 6 Old 06-14-2013, 04:32 PM Thread Starter
dezimmer
TPMS Sensor
Good evening,
I am wondering if the following is a sign that the TPMS sensor has gone bad. The right rear tire is the one in question. Please see attached picture.
I know there have been numerous threads pertaining to this, but have not seen any photos.
Your input is greatly appreciated.
Thanks.
dezimmer is offline
post #2 of 6 Old 06-15-2013, 07:07 PM
guls
2015 JK Wrangler
Yes, looks like it. Is TPMS light on
guls is offline
post #3 of 6 Old 06-15-2013, 11:52 PM
trax95008
2006 XK Commander
Why do you have such a large difference in pressure between tires? I keep them within 1psi of each other. The difference you have can cause handling issues
trax95008 is offline
post #4 of 6 Old 06-17-2013, 01:36 PM
Jeepforthewin
2010 JK Wrangler
You should be fine. Ive had a couple of mine do this before and then 15 mins later showing numbers again. Correct me if im wrong but im assuming its just recalibrating maybe
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #5 of 6 Old 06-17-2013, 02:21 PM
corswandtm
2007 WK
Mine does the same every now and then. It also says Service Tire Pressure System about 3 minutes into every drive.
2007 WK Red Rock Limited - 5.7 HEMI w/QD-II - Stainless 22" Magnaflow muffler - AFE Stage 2 CAI - Bilstein HD shocks/struts - JBA Strut Spacers - 245-70/17 Firestone Destination AT
corswandtm is offline
post #6 of 6 Old 06-20-2013, 04:45 PM
GeeEssFore
Most of the time they will do this if the battery is failing or some fix-a-flat is used inside tire.
06 Commander
GeeEssFore is offline
