-   WK Grand Cherokee & XK Commander Forum (http://www.jeepforum.com/forum/f67/)
-   -   TPMS Sensor (http://www.jeepforum.com/forum/f67/tpms-sensor-1536542/)
dezimmer 06-14-2013 03:32 PM
TPMS Sensor
1 Attachment(s)
Good evening,
I am wondering if the following is a sign that the TPMS sensor has gone bad. The right rear tire is the one in question. Please see attached picture.
I know there have been numerous threads pertaining to this, but have not seen any photos.
Your input is greatly appreciated.
Thanks.
guls 06-15-2013 06:07 PM
Yes, looks like it. Is TPMS light on
trax95008 06-15-2013 10:52 PM
Why do you have such a large difference in pressure between tires? I keep them within 1psi of each other. The difference you have can cause handling issues
Jeepforthewin 06-17-2013 12:36 PM
You should be fine. Ive had a couple of mine do this before and then 15 mins later showing numbers again. Correct me if im wrong but im assuming its just recalibrating maybe
corswandtm 06-17-2013 01:21 PM
Mine does the same every now and then. It also says Service Tire Pressure System about 3 minutes into every drive.
GeeEssFore 06-20-2013 03:45 PM
Most of the time they will do this if the battery is failing or some fix-a-flat is used inside tire.
The time now is 02:13 AM.
