TPMS issues - JeepForum.com
post #1 of 18 Old 01-02-2014, 09:26 AM Thread Starter
toycarrier
TPMS issues
So the CRD made it to WI and back on a pretty amazing 3,000 mile journey. While we were in Northern WI, temps got down to -24 degrees Fahrenheit. Absolutely freezing cold. It was cold enough that my locks didn't want to unlock for a minute haha. Anyways, the morning it was that cold out we were leaving to head back home to VA. Pretty much right away I ran into a TPMS issue that is still a problem now (back in VA).
After the Jeep warmed up for about 10 minutes at idle, we drove down the long drive way and all of the sudden the dash screen to the tire pressure monitor screen and the light flashed. It showed no readings for either tire on the left side of the vehicle. I figured something was frozen so we just kept on our way. Well, the ice eventually all melted off by WV but the sensors never came back to life. Still showing no readings out of the left side of the Jeep. What should I start checking? Are they more than likely bad since nothing is being shown except for -- on both?
Thanks guys!
Jeff
toycarrier is offline
post #2 of 18 Old 01-02-2014, 12:52 PM
Drudgery1971
2007 WK
Mine have went berserk before as well - usually snow/ice/heavy rain and they will flash --- (as in no reading). I have never had them go bonkers for that many miles though. I would wash the wheels/wells really well - actually the whole Jeep since you went through salt land from WI to VA. Then I would un-hook battery for a few minutes and re-connect. Vehicles are after all dozens of computers all chunked together and need a time out to square up. I would also imagine you had to inflate your tires after a day in WI due to temp being that low - would likley drop PSI by 3-4 psi easy. Mine trip at 28-29 psi.
2007 WK Limited 3.0 CRD - Stock (Mine)
2010 XK Sport 5.7 Hemi - Stock (Wife)
Drudgery1971 is offline
post #3 of 18 Old 01-02-2014, 01:22 PM
jbarrett
I would guess start by checking the actual sensors on the wheels? If they froze up, maybe they are permanently damaged. The fact that you are getting no reading (vs. an incorrect reading) would lead me to believe the sensors are inoperable.
jbarrett is offline
post #4 of 18 Old 02-04-2014, 07:42 PM Thread Starter
toycarrier
I've been ignoring this issue for a bit too long now. Is there anything else to check out? For both sensors on the left side to go out immediately i'm thinking it's something farther down the line than the sensors themselves. Is there a fuse or anything like that I can check for the left bank?
Thanks,
Jeff
post #5 of 18 Old 02-04-2014, 08:27 PM
ducktail
2009 WK
They do go bad and maybe the cold just finished them off.
I have found out that the aftermarket ones I have are not near as good as factory.
2009 GC Limited. 265 70 18 is the only change to date. Bought some Rubicon 17" wheels and put BFG M/T's on for hunting season OME HD Front, OME MD rear, winch to come, basket and lights bars first
ducktail is offline
post #6 of 18 Old 02-05-2014, 07:27 AM
yzjwk
2005 WK
Thanks,
Jeff
Assuming of course you checked your tire pressures with a guage then I would get the codes read and see if that tells you anything .You can try the key dance , but i'm not sure if you'll get anything from just the PCM as codes stored should be in the WCM. You have 3 receivers in the premium system - 1 in each front wheel well and 1 in the right rear . The left rear is assumed by the WCM through process of elimination . Because your problem is with the left side , i will guess and say the problem is with your front -right wheel well receiver . The left also goes out because now the WCM cannot tell the difference between front and rear anymore . I would pull the wheel well liner and look at the Reciever connections and wires if nothing can be detirmined with the fault codes. You will have to bend the wires right at all the connectors and possibly the entry into the Receiver and see if they are broken. It can be tricky to spot so have a good flashlight . Also take any connectors apart and make sure they are clean and dry .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #7 of 18 Old 02-05-2014, 08:34 AM
Clirry
2014 WK
Heck yeah! I got 4 aftermarkets (doorman) went to dealer like 4 times to get them fixed properly. apparently they broke one tpms and replaced w cheap rubber stem. one tpms still leak slowly like overnight and 3-6 psi loss. I literally air it up every mornings. other 2 tpms are good.
Brilliant Black Crystal Pearl, Limited, OR1, QTII, Plasti dipped
Clirry is offline
post #8 of 18 Old 02-05-2014, 03:10 PM
DeChache
2003 WJ
The first big cold snap we had here took out 2 of the TPMS sensors on my wifes WK. Don't know what year your Jeep is, but the sensors only tend to last 5-6 years before they fail.
DeChache is offline
post #9 of 18 Old 02-21-2014, 08:25 AM
jtodaro
2014 JK Wrangler
What happens when the TPMS get's taken out? The reason I ask is I just bought a used 05 LTD Hemi (which according to WKJeeps.com, has the base TPMS as standard with the Prem as optional), and when I goto the TPMS screen in the EVIC it doesn't display anything (not 1 wheels, not 4 wheels, not even an error, just a blank screen). I'm wondering if the previous owner let all 4 sensors die and didn't replace. Would I get an error if they removed all the TPMS sensors entirely?
2014 JKU Sport Anvil
jtodaro is offline
post #10 of 18 Old 02-21-2014, 09:12 AM
audiophonicz
2007 WK
There is also a TB flash for the wireless unit on these for the constant TPMS message. My rear passenger loses connection all the time, even after rotation.
audiophonicz is offline
post #11 of 18 Old 02-21-2014, 11:37 AM
jtodaro
2014 JK Wrangler
Think mine is related to the TPMS light that just came on (since I'm new to this WK, I didn't know what the light was till I looked it up). Will check pressure and see if it goes off. Odd that my 05 Ltd Hemi didn't have the premium TPMS option. Will see what my build sheet says when I get it back from Chrysler Cust Assistance.
jtodaro is offline
post #12 of 18 Old 02-21-2014, 12:25 PM
yzjwk
2005 WK
My limited Hemi doesn't have the premium system so If you have a TPMS screen in the EVIC then you HAVE the premium system .
That screen doesn't exist with the base system .
On mine with no sensors in my winter rims, the TPMS light chimes when i first start the vehicle and then goes away after a few mi . It comes back solid every now and then . Most times it doesn't ding , but once in awhile on a longer ~60 mi drive it will ding once .
90 YJ Islander 4.2L
2010 MK Patriot
yzjwk is offline
post #13 of 18 Old 02-27-2014, 02:03 PM Thread Starter
toycarrier
I'm not sure if this is going to work or not but i've swapped my passenger side rear tire with my drivers side front tire to see if I can get a signal from the TPMS. Pulled the negative terminal from the battery, now just waiting and will go check. Will I need to drive on the system for a bit so it "learns" ?
2008 Grand Cherokee CRD Limited
post #14 of 18 Old 02-27-2014, 02:05 PM
jtodaro
2014 JK Wrangler
You technically are not supposed to do that IF you have directional tires (should only swap front to back, same side).
With that being said, good luck and I hope that confirms whats going on.
jtodaro is offline
post #15 of 18 Old 02-27-2014, 02:12 PM Thread Starter
toycarrier
I hear ya, this is a temporary thing to figure out if it's a bad sensor or some other problem. I've got new tires and a lift waiting to go on. I just want to figure this TPMS issue out before I have new tires mounted and balanced.
