Tpms - JeepForum.com
post #1 of 14 Old 08-07-2013, 08:07 PM Thread Starter
lafacej
Tpms
I got a new sensor put on my 05 limited at the dealership bc the "service tire pressure system" light was on and they said I needed one on the spare wheel/tire. I left the dealership and the light came back on, is there a procedure to set the sensor or do I need to take it back?
Thanks
lafacej is offline
post #2 of 14 Old 08-07-2013, 08:57 PM
Anon155
2005 WK
It should reset after 10 miles or so. It does it automatically once it reads the sensor. They may have put the wrong frequency in by mistake. I'd take it back if the code doesn't clear. Hopefully you didn't have more than 1 go bad.
05 Jeep Grand Cherokee: ORT 4X4; Khaki #55
Too many mod's to list...
Anon155 is offline
post #3 of 14 Old 08-07-2013, 09:00 PM Thread Starter
lafacej
Well my display reads all4 tire pressures so I think they're alright I'm assuming its the spare then. I actually bought it from someone here on the forum so hopefully it's the right frequency. I'll put a few more miles on and see how it looks.
lafacej is offline
post #4 of 14 Old 08-07-2013, 09:31 PM
Anon155
2005 WK
Yeah there's 2 different frequencies Jeep uses. 315mhz and 433mhz I believe. Your 05 should use the 315. You may also check the air pressure in the spare. If they didn't fill it up to the right pressure, that could be the reason it's going off. But I doubt the dealer would make that mistake...
Anon155 is offline
post #5 of 14 Old 08-08-2013, 03:11 PM Thread Starter
lafacej
Spoke to the dealer today and they claimed I have a 2007 so maybe they input that in the programming of the new sensor and that caused the mistake bc I most def have a 2005. I will check the air in the spare but I would have assumed they filled it up unless it isn't holding air. Wouldn't that trigger the dash light though?
lafacej is offline
post #6 of 14 Old 08-08-2013, 03:23 PM
Anon155
2005 WK
If it wasn't holding air it would trigger the dash light once psi is below the acceptable range for the tpms. There shouldn't be any need for programming of a new sensor.....It should automatically sync up to the cars computer after driving it like I said. Even if the dealer thought your jeep was an 07, I believe they still used the same frequency that year. The sensor is either bad, or the wrong frequency. Thats the only 2 logical things I can think of.
Anon155 is offline
post #7 of 14 Old 08-08-2013, 05:21 PM
yzjwk
2005 WK
That's true , but the replacement is in the spare. . The dealership may have to "wake up " the sensor, if they were even right in replacing it in the first place . I would take it back , in fact they would have seen my P.O'd butt again as soon as that light came back on.
here's the info from the service manual
Good luck
The battery operated tire pressure sensors lay dormant (Park Mode), then wake and start transmitting (Drive Mode)
when the vehicle first reaches speeds over 20 mph (32 km/h). Once the wheels stop rotating for a period of approximately
20 minutes, the sensors shut down until again awaken. Although not transmitting as when in Drive Mode,
while in Park Mode, the sensors still transmit approximately once every 13 hours to let the receiver know air pressure
status at that time.
Using an RF signal, each sensor transmits tire pressure data approximately once every minute. Each sensorís
(transmitter) broadcast is uniquely coded so that the wireless control module (WCM) can monitor the state of each
of the sensors on the four rotating road wheels. The WCM automatically learns and stores the sensorís ID while
driving after a sensor has been replaced. There is no formal retraining procedure necessary.
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #8 of 14 Old 08-10-2013, 05:03 AM
GeeEssFore
They will either have to program it with the scan tool or if they put it on the drive tire for a few miles it will relearn. Sometimes spares are a pain to get woken up and auto relearn. We usually just program them with a scan tool
06 Commander
GeeEssFore is offline
post #9 of 14 Old 08-12-2013, 06:57 PM
kentman
kentman's Avatar
2006 XK Commander
You can just put the spare on and check its integrity as if it were in the mainstream.
I got the Service TPMS System warning on the WJ, and I too thought that it was the spare that was causing problem because the other four sensors appeared to be reading out normal. I swapped the spare sensor. It reprogrammed fine, but the message remained. I swapped out the EVIC. During that process, I found that the driver front sensor was slow to relearn. I ended up swapping out that sensor on a hunch, and everything went back to normal.
It seems as though one sensor that is just going bad will trip the message, but it may continue to read normal pressures for a while. When in doubt, swap out active sensors, particularly if they are nine or ten years old.
I did not need to use any tool to program the sensors. I used a local tire shop to install the sensors. I did the relearn stuff myself using the EVIC and the Jeep-supplied magnet.
'06 XK Limited, 5.7L, QD II, Black, 163K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 126K
kentman is offline
post #10 of 14 Old 08-12-2013, 08:29 PM Thread Starter
lafacej
Funny you said that because the dealer told me that my front driver one is also going even though it is reading the correct pressure on my dash. Oh well, I'll have to order another one.
lafacej is offline
post #11 of 14 Old 08-13-2013, 08:05 PM
Megs_Revenge
2005 WK
lafacej, what's the name of the dealership you are using?
2005 Silver WK 5.7L Hemi
Silver WK club #69
Oo|||||||oO
Megs_Revenge is offline
post #12 of 14 Old 08-13-2013, 09:42 PM Thread Starter
lafacej
Monroeville Chrysler Jeep and Dodge. You think when I had them check on the light and out a sensor in they would have actually checked that the sensors worked properly. Curious, why do you ask?
lafacej is offline
post #13 of 14 Old 08-15-2013, 01:23 AM
kentman
kentman's Avatar
2006 XK Commander
I worked in Monroeville for six years, but never used the Jeep dealer. My first Jeep ('97 ZJ) came to me in '99 one year after leaving Monroeville. I have been driving Jeeps ever since.
Regarding testing the sensor, they may be intermittent. They may show up good one minute and bad the next. If you have old sensors and TPMS issues, then the first step should be to swap out sensors.
If that does not work, then move on to electronic module issues.
kentman is offline
post #14 of 14 Old 08-17-2013, 05:06 PM
Megs_Revenge
2005 WK
I've heard bad things and good things regarding Monroeville Jeep. Of course, Jim Shorkey (who I have my warranty through) isn't wowing me either with their service.
Silver WK club #69
Oo|||||||oO
