Towing Package Aftermarket? - JeepForum.com
post #1 of 12 Old 06-08-2006, 06:09 PM Thread Starter
rtaylo25
I am about to purchase a Commander with all the options I've been looking for - right color, the whole bit - only problem is no towing package. Does anyone know whether this is something that can be added as an aftermarket accessory? Or is the towing hitch integrated into the frame - thus, you either can have at purchase or not at all. Thanks in advance for any information you can give me.
RT
rtaylo25 is offline
post #2 of 12 Old 06-08-2006, 07:51 PM
ks03rubicon
You can physically have parts put on that'll let you "tow", but it won't be the same unless you change a whole lot. The hitch is obvious, next would be the wiring harness. Also, the 'tow package' includes a tranny cooler and different gears.
Our's (which had the class IV towing package) also has a 'tow' button on the center dash panel that basically locks out overdrive. You can add some of or all of these to tow, but the price will be a lot more than the factory option.
2003 Rubicon (Khaki),
3 1/2" Rubicon Expess lift, Currie Anti-Rock swaybar,
305 MTR's, Skid Row engine plate, Warn M8,000# winch.
ks03rubicon is offline
post #3 of 12 Old 06-09-2006, 06:40 PM Thread Starter
rtaylo25
I found out that it could be added for $499 plus tax - that is the 7 way wiring and Class IV towing hitch. Are you saying though, that the gear ratios would not be set up right to tow? Would it not be wise then to try and tow a 4000lb boat with the 4.7L V8 if the towing package was installed aftermarket?
RT
rtaylo25 is offline
post #4 of 12 Old 06-09-2006, 08:16 PM
pwloomi
I don't think that you would have any problems, just may not tow as well as ones that are geared different.
pwloomi is offline
post #5 of 12 Old 06-11-2006, 08:38 AM
JeepCollector
The towing package doesn't change the axle gearing - there is only one gear for the 4.7L and it's a 3.73. Most of the structure for the hitch is already there, so one small bolt-on part to fit the 2" hitch insert will complete that. I believe that transmission coolers are standard also. Make sure it has the mechanical engine fan.
If it's at a dealer try to work the tow package into the deal. Good luck.
Steve
JeepCollector is offline
post #6 of 12 Old 06-11-2006, 03:01 PM
nhpso224
Yup, they are pretty much standard these days. Mine has everything but the hitch and harness. Dealer said that they could put the "MOPAR" hitch and harness on for $250.
'99 XJ Classic, RE 5.5", 15x8 Baja Champs , 33x10.5 BFG MT's,. Bosh fogs, Yakima rack and alot of other stuff
'06 XK Commander, 4.7l, Crystal Inferno Red Pearl, Dark Gray 5 spokes, Slate Gray Leather intreior, Command view skylights
nhpso224 is offline
post #7 of 12 Old 06-19-2006, 11:55 PM
mca1977jpsnet
Re: mopar hitch p#s
All the parts are avail for the XK (commander) through Mopar for a OEM style hitch. You'll need the following parts.
1. hitch assm p# 82208228 $89.00 1.25" rated at 3500 lbs or
P# 82209219 $109.00 2.0" rated at 7200 lbs (highly reccomend the 2")
2. install bezel p#82209527 msrp $65.00
3. tow wiring p#82209766 msrp $79.00 (includes both 7 and 4 prong wiring)
After installing the hitch your tow rating will vary depending on your drivetrain options. A 3.7 v6 won't out tow a HEMI of course.
Check out this link: http://www-5.jeep.com/vehsuite/VehicleCompare.jsp
mca1977jpsnet is offline
post #8 of 12 Old 06-20-2006, 12:06 AM
INDO
can you provide the website where you received those price quotes?
thanks
INDO is offline
post #9 of 12 Old 06-20-2006, 12:35 AM
mca1977jpsnet
MOPAR website
sure its MOPAR.COM link: http://www.mopar.com/m_acc_cat.jsp?c...=1150785315844
post #10 of 12 Old 06-20-2006, 09:49 PM
rikmeister
mine was missing too and dealer quoted me 255 to add the class IV hitch.
rikmeister is offline
post #11 of 12 Old 06-21-2006, 10:35 AM
cmd peej
As pointed out in this thread, the TOW button on the dash ONLY locks out the 5th gear. You can do the same thing with the "selecto" gear shift (or whatever it's called.)
What I don't like about the TOW switch is that everytime I stop (and turn off the ignition) while on a towing operation. it's necessary to reengage the TOW switch again on startup. For some reason, it always defaults to off when the ignition is switched off. Pain in the *** when towing my boat.
I DON'T understand why it doesn't operate the same as the backup aid. You turn that off and it stays off until you turn it back on.
FYI, the manual also recommends limiting operation with high tow loads and in mountains to 3rd gear as the highest gear. So, in many cases, the TOW switch might as well not be there.
cmd peej is offline
post #12 of 12 Old 07-12-2006, 10:54 AM
bigjimslade
2007 KJ Liberty
The 82209219 part (2") said only 2,000 lbs without weight distributing equipment. Isn't that supposed to be 5,000 lbs? tongue weight seems low as well.
Do you have to have the bezel? They kind of make it sound like it is just to make it look like a factory install.
07 KJ with OME springs, Bilstein shocks, some extra's for a total of about 3.5" of lift, JBA 4.5 UCA's, riding on 245/75-16 Duratracs mounted on black Moabs.
bigjimslade is offline
Towing Package or Towing Prep Package? lma1973 ZJ Grand Cherokee Forum 26 03-07-2012 08:38 PM
Aftermarket tow package robtre WK Grand Cherokee & XK Commander Forum 9 05-30-2009 02:34 PM
How do i know if i have towing package? lma1973 ZJ Grand Cherokee Forum 11 11-07-2006 08:02 PM
Towing Package? redgrandcheroke ZJ Grand Cherokee Forum 6 02-11-2006 06:48 PM
Towing Package countertop ZJ Grand Cherokee Forum 9 10-23-2005 03:44 PM
