Towing Hitch - Page 2 - JeepForum.com
post #16 of 28 Old 09-23-2013, 07:47 AM
LiftedWK
For gods sake......don't take it to a dealership to get it wired.
LiftedWK is offline
post #17 of 28 Old 09-23-2013, 04:40 PM
LouC
2007 WK
Not sure what they would charge because I installed the hitch and wiring in my 98 myself (very easy on the older models) and my 07 came with the tow package. It is definitely worth having a hitch though. I've used it many times, for moving big projects with rented trailers, towing boats etc. You can use an aftermarket hitch (like a Draw Tite or Curt) but I'd get the OE wiring. Less troubles that way....
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
post #18 of 28 Old 09-25-2013, 10:08 PM Thread Starter
floresnick
2006 XJ Cherokee
so where would I get the OE wiring and I have a friend who will mount the hitch for me... i'm just trying to figure out which one to buy
floresnick is offline
post #19 of 28 Old 09-25-2013, 10:33 PM
longboy
2006 WK
OE: http://www.justforjeeps.com/hirewihatrto3.html
Just make sure you get the correct year for your Jeep.
2006 5.7l WK
longboy is offline
post #20 of 28 Old 09-26-2013, 10:21 PM Thread Starter
floresnick
2006 XJ Cherokee
do I want the 7 way round or the 4 way flat?
post #21 of 28 Old 09-27-2013, 09:53 AM
XK1982
2006 XK Commander
so when we bought our Jeep it didn't come with a towing hitch and now that I'm buying a 4 wheeler and don't have a truck to load it in, we're buying a trailer but I sorta need a hitch to do so... what is the best one you guys would recommend, I may buy one of eBay just cuz that's the cheapest route, but I want a good feedback from the guys who live Jeep! TIA
I'd definitely go with a dealer/MOPAR Class III hitch. It's not that expensive and won't rust away like the aftermarket one's always do. I installed mine myself. It comes with a template to cut the plastic rear bumper. Easy to do with a dremel. Most time consuming part is just removing the bumper, just a bunch of plastic push snaps. Goodluck!
2006 XK Commander, 4.7L V8, Quadra-Trac II, 6.25" Modified Superlift, Jeepin by Al's front UCA's, Rusty's Adjustable rear LCA's; 35x12.5R17 TOYO Open Country MT's; Method NV305 17x8.5 wheels
XK1982 is offline
post #22 of 28 Old 09-27-2013, 10:05 AM
XK1982
2006 XK Commander
I'm so confused here guys i'm making this harder than it has to be I know but ya!
My 06 commander came with the towing package, trans cooler, tow-haul, etc. but no hitch and no trailer wiring harness. If you bought the jeep w/o the hitch I highly doubt it has the towing wiring harness.
That being said I purchased a 7 pin round chrysler OEM trailer harness on ebay from a dealer (super easy to install). The 7 pin has more options than the flat and if you want eletric trailer brakes I recommend the 7 pin round. Start at the rear of the vehicle, plug into rear drivers taillight and just start routing the wire up to the front of the jeep. No splicing, soldering, etc. just plug and play! All you have to do is zip tie it out of the way and make sure you don't hit the exhaust or moving parts. Instructions that are pretty self explainatory. Goodluck!
XK1982 is offline
post #23 of 28 Old 09-27-2013, 10:06 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
You want a 7 way.
4 flat does not support trailer brakes/brake controller.
If it's not included in the wiring package, then you'll want to run a power wire for a brake controller from under the pedals back to the plug.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #24 of 28 Old 09-27-2013, 04:07 PM
LouC
2007 WK
The factory harness on my 07 WK came with both the 7 round and 4 flat.
If you have to choose between get the 7 and then you can tow a trailer that has electric brakes . If you have to tow one that has no brakes or surge (hydraulic) brakes you can use a 7 to 4 adaptor.
LouC is offline
post #25 of 28 Old 09-27-2013, 07:16 PM
JackB1
2008 WK
I installed a Curt hitch on my 08 WK Laredo. It was simple and looks custom for one that is below the bumper. The custom wiring package only took 10 minutes to install.
JackB1 is offline
post #26 of 28 Old 09-30-2013, 03:47 PM Thread Starter
floresnick
2006 XJ Cherokee
thanks guys I appreciate all the help... I'll just buy an eBay one I'm sure it'll work as long as the rust doesn't take away from the reliability from the hitch but if I have any other questions I'll make sure to get a hold of you guys!
post #27 of 28 Old 10-05-2013, 12:22 AM
Drewd
I have a hitch (factory OEM) from a 2007 Jeep Grand Cherokee. $45 plus 15 shipping and its yours!
PM me.
Drewd is offline
post #28 of 28 Old 10-22-2013, 08:03 PM Thread Starter
floresnick
2006 XJ Cherokee
I sent u the message... so that hitch that I posted if I just buy that one, where will I put my trailer connector connect at on it?
