Towing 6'x12' UHaul trailer behind 2007 4.7L 4x4 Laredo Limited with Factory hitch - JeepForum.com
post #1 of 33 Old 07-25-2013, 02:35 PM Thread Starter
adopttwins
2007 WK
I'm trying to figure out how much I can pull behind my '07 Grand Cherokee 4.7L Laredo. I need to fill a 6 x 12 foot UHaul with household stuff from Vermont to California. What can I expect for weight limits and how much will it affect the gas mileage to the point I might as well just throw the stuff out and start over?
adopttwins is offline
post #2 of 33 Old 07-25-2013, 03:17 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Per wkjeeps.com:
4.7 4x4 w/ tow group IV package:
gross trailer weight - 6500#
gross combined weight rating - 11,450#
max tongue load - 720#
http://www.wkjeeps.com/wk_towing.htm#WEIGHT
fuel econ will depend on many things - i.e.- speed, topography, load weight, etc.
Best case I'd say will be around 12mpg give or take.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #3 of 33 Old 07-25-2013, 06:32 PM
TimM
2007 WK
Earlier this year I towed a 7'x14' loaded trailer behind my old 2004 4.7GC. Mainly freeway with some high country for a distance of about 700 miles. Fuel consumption about 10mpg - bit better on the flat.
After I unloaded and unpacked some cartons that had not seen daylight for several years, I did ponder why I went to the expense of carting such stuff. My advice would be to do a 'hard' cull of your stuff and only take the really good gear preferably in a smaller trailer. My trailer was enclosed and quite high. It was supposed to be their 'streamlined model'. Glad I didn't get the non- streamlined version!
Good luck
TimM is offline
post #4 of 33 Old 07-25-2013, 07:33 PM
LouC
2007 WK
As long as you're not loading it with bricks it should be no problem at all, as long as you load most of the weight in front of the axle, and have it set level (correct drop on the hitch). I have towed 2 U-Haul trailers with my WK and for both it took a 6" drop hitch for it to tow level. So that gives you a good starting point, pick up a 6" drop draw bar and 2" ball.
take a look at 'intro towing with a WK' thread.....
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
post #5 of 33 Old 07-25-2013, 08:29 PM Thread Starter
adopttwins
2007 WK
Thanks all for the quick response. I wish my wife was willing to throw some of this s..t away as I'll be 6 feet under before any of it sees the light of day. Oh well, 10 MPG is awful, but hiring movers is more awful. What a great community and great help!!!!
post #6 of 33 Old 07-26-2013, 12:40 AM
LouC
2007 WK
Before you take off make sure the adjustable hitch that they use is tight and check the tire pressures. That adjustable hitch bangs and clunks more than one that fits the ball exactly so just be aware of that. If you're new to towing it could be a little concerning. There is normally some play in how the drawbar fits the receiver hitch on the Jeep and you may hear a bit of clunking from that now and then, but those U Haul couplers are noisy for sure. My boat trailer even with surge brakes is much quieter.
LouC is offline
post #7 of 33 Old 07-26-2013, 12:21 PM Thread Starter
adopttwins
2007 WK
Do I need to go so far as to install a transmission cooler?
post #8 of 33 Old 07-26-2013, 04:24 PM
LouC
2007 WK
If your WK has the tow package it probably already has it, I know my 07 does. I added a B&M Supercooler to my 98 when I was using it for towing.
LouC is offline
post #9 of 33 Old 07-26-2013, 09:15 PM
Tango.
2008 WK
That is a long drive. You'll be lucky if you get 8 mpg towing that. You have some mountains on that route.
plus you might be better of buying a "used" motorcycle hauler trailer, as they are lower height (cab height) , better mileage, and just selling it when you get to Cali. Used trailers sell for about the same price you buy them for. good tires, trailer brakes, and bearings are important.
Trailers are easy to sell in Cali, you might even pre-sell it, and get paid to haul it there?
Tango. is offline
post #10 of 33 Old 07-29-2013, 03:16 PM
10Xk
2014 WK
Originally Posted by JeepN4KC
Per wkjeeps.com:
Max tongue weight for a 07 4.7l is 650lbs.
Can't go wrong with the owners manual, free at
http://www.jeep.com/en/owners/manuals/
10Xk is offline
post #11 of 33 Old 07-29-2013, 03:41 PM
JeepN4KC
JeepN4KC's Avatar
Wonder why the discrepancy?
EDIT:
Just realized 650# fits better at 10% of gross trailer.
Never even thought of this anytime I referenced wkjeeps for towing info.
~Mike~
WK
XJ
JeepN4KC is offline
post #12 of 33 Old 07-30-2013, 07:57 AM
yzjwk
2005 WK
EDIT:
My 05 owners manual states 720# for all 4.7's .
the 06 owners manual states 650# for all 4.7's both 2 an 4x4 .
what i find interesting is the 07 owners manual makes a distinction between a normal 4.7L/Automatic with tongue weight of 350# and 4.7L/Automatic
(w/Trailer Tow Group IV) - tongue weight of 650# .
Also , without the trailer tow group IV your only rated for 3500# total .
OP , if your not sure , you should get a build sheet either on line or from the dealer and make sure you have the trailer tow group IV.
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #13 of 33 Old 07-30-2013, 09:07 AM
colinzj
2006 WK
If you have the Class IV tow hitch and you bought the vehicle new, you have the Trailer Tow Group IV.
If you bought it used, it's worth checking what you've got. 2007 is when the cost-cutting went into effect and Jeep started using a cheaper cooling fan on vehicles not shipping with the Class IV hitch (which is why the 2007 manual starts to distinguish between them).
Upgrading to the "tow group" if the previous owner didn't do it is as easy as walking up to the parts counter asking for the Mopar cooling fan upgrade.
Without the fan, you're rated at 350/3500 on either hitch. With it, you're at 650/6500 on the IV.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
post #14 of 33 Old 08-01-2013, 01:39 PM
dorelse
So, I purchased a 2008 XK Sport, 4.7...is that true for me as an XK owner as well? Cooling fan upgrade?
(I'm a very new owner, trying to figure out my towing situation for my boat.)
dorelse is offline
post #15 of 33 Old 08-01-2013, 04:15 PM
Umbrella
2006 XK Commander
Every Jeep owner should have the build sheet.
You can get it through email from the "Owners" section of the Jeep website.
P.S. It's free. The novelty of something free for your Jeep should be incentive enough!
2006 XK 4.7 Limited
1995 XJ 4.0 Sport
Umbrella is offline
2007 , grand cherokee , tow capacity , uhaul
