towing - JeepForum.com
post #1 of 5 Old 07-07-2006, 11:28 PM Thread Starter
esposa143
towing
i am going to tow a small car mistu*****y (cant spell) on a trailer for about 1800 miles louisiana to utah. i have the class IV tow package should i have any probs? any recomendaions. only 3000 miles on commander.
esposa143 is offline
post #2 of 5 Old 07-08-2006, 10:07 AM
HemiCommander
2010 JK Wrangler
What model JC are you referring to? Do you know the tow rating on the JC and the weight you will be towing?
The HEMI or other V8 should not have any problems... not sure about the 6
HemiCommander is offline
post #3 of 5 Old 07-08-2006, 02:23 PM Thread Starter
esposa143
i have the 5.7 v8 hemi and the class IV towing package. most of the time i should be able to just push the button and go. but when i hit mountian areas should i drop it down to third?
post #4 of 5 Old 07-09-2006, 11:53 PM
SGilbert
2014 KL Cherokee
The Hemi will take all you can throw at it. If "D" concerns you in the mountains, just activate the "tow/haul" button on the center stack. That'll put your shift points at better rpm's to tow, and effectively keep you in 4th gear tops.
'14 Cherokee Ltd V6 AWD; '11 Lincoln MKT AWD EcoBoost; '00 Regal 29' Commodore
SGilbert is offline
post #5 of 5 Old 07-10-2006, 01:54 AM
suerto
Thank you Gilbert!!!
(I am esposa143's husband).. We were having this discussion and she told me that she read here on the forum that all the tow button did was disable the overdrive.... We also have a 96' corvette and you can reprogram the shift points in that thing, (its a Collector's Edition with the OBD2 eeprom) so I figured the tow option did more than just turn off overdrive.. (I specifically said it prolly raises the shifting RPM's and such)...
Alas, I will not be joining her and my mother on this adventure (have to work, which is where I am now) and so they will not have my expertise on the expidition.
Suerto
06 5.7L Commander Limited 2WD
01 I6 Cherokee Sport 2WD
96 CE LT1 Corvette
suerto is offline
Towing Package or Towing Prep Package? lma1973 ZJ Grand Cherokee Forum 26 03-07-2012 08:38 PM
WK towing an XJ nostaw22 WK Grand Cherokee & XK Commander Forum 4 06-02-2009 10:28 AM
Going to be towing a Jet Ski mdoug445 ZJ Grand Cherokee Forum 30 03-28-2007 03:12 PM
Towing a TJ QElliott17 WK Grand Cherokee & XK Commander Forum 4 03-19-2007 08:00 PM
Towing ..Etc... pineapplegti ZJ Grand Cherokee Forum 2 03-15-2005 12:11 AM
