Tow/Haul button and question - JeepForum.com
post #1 of 10 Old 02-16-2014, 08:16 PM Thread Starter
MarvinTm
2008 WK
so i read Manual and i shows a tow/haul button and a light for the gas instrument cluster but not for the CRD.
question is this
1: is it auto for the CRD and
2: if it is will it run electric trailer breaks
thanks
MarvinTm is offline
post #2 of 10 Old 02-16-2014, 08:21 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
question is this
thanks
1. Doubtful
2. No. You have to wire in a brake controller to run trailer brakes.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #3 of 10 Old 02-16-2014, 08:23 PM
xSoFx
1987 XJ Cherokee
To add to that, if you have the towing package I believe there is a harness pre wired for a brake controller.
xSoFx is offline
post #4 of 10 Old 02-16-2014, 08:43 PM Thread Starter
MarvinTm
2008 WK
how could i tell if it is prewired?
my trailer right now does not have them but our next will.
thanks all.
ya the tow/haul is strange as the CRD has the coil in the spot for the tow/haul light .
MarvinTm is offline
post #5 of 10 Old 02-16-2014, 08:52 PM
JeepN4KC
JeepN4KC's Avatar
There is nothing "prewired" with the towing package as far as a brake controller. You have to wire everything in. I have the towing package but I installed my brake controller.
Reference this post in my build for a walk through:
http://www.jeepforum.com/forum/f67/m...l#post15980009
The only thing that is already there is a green power wire (that sends power to the hitch harness) to the left of the brake switch.
~Mike~
WK
XJ
JeepN4KC is offline
post #6 of 10 Old 02-16-2014, 10:17 PM Thread Starter
MarvinTm
2008 WK
thanks
MarvinTm is offline
post #7 of 10 Old 02-17-2014, 03:13 AM
james_2k
2003 WJ
id guess the crd doesnt need a tow mode because it is fine to do it in normal gear ranges. what with it having all the torque low down.
james_2k is offline
post #8 of 10 Old 02-17-2014, 04:05 AM
caulk04
2008 WK
Seems that way. The CRD already runs high in it's RPM range due to the strange gearing DCX paired it with so a tow/haul wouldn't make sense.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #9 of 10 Old 02-17-2014, 06:46 AM
jaje
2007 WK
You don't need a tow / haul program with the transmission as the CRD will handle any heavy loads without a problem. It's gearing in the tranny is more apt for a gas engine so on a diesel engine it runs the RPMS unnecessarily high and unfortunately really reduces its cruising speeds to 75 mph max or less (runs near 3k at 75-80 mph).
'14 WK2 EcoDiesel Limited
'13 Subaru BRZ
#74 Exocet - NASA ST3 / E0
jaje is offline
post #10 of 10 Old 02-17-2014, 12:22 PM Thread Starter
MarvinTm
2008 WK
thanks all.
MarvinTm is offline
