Tool compatability? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Tool compatability?
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! The Original 3/8" Ruffstuff Diff Cover!The Cure for your Tie Rod Roll!
Unread 03-14-2015, 12:16 AM   #1
Hockeyhead777
Tool compatability?
Does anyone know if the Spare Tire Driver Nut is the same size between the 2002 and 2007 GCs?
I'm looking at some replacement tools for sale and thinking that it should be the same size, but I'm not 100% certain.
Hockeyhead777 is offline   Reply With Quote Quick reply to this message
Unread 03-14-2015, 07:59 AM   #2
joe989
2008 WK
isnt it the tire iron that lowers it? that would be a 3/4 or 19MM socket(same size)
joe989 is offline   Reply With Quote Quick reply to this message
Unread 03-14-2015, 09:03 AM   #3
Hockeyhead777
The Spare Tire Driver Nut is a square peg used in raising/lowering the spare tire which is stored under the trunk on the exterior underside of the vehicle, not a standard nut used as a Lug Nut.
Unread 03-14-2015, 09:12 AM   #4
LouC
2007 WK
The 02 does not have the tire underneath as the WK does, it's in a well in the cargo floor.
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline   Reply With Quote Quick reply to this message
Unread 03-14-2015, 09:40 AM   #5
Hockeyhead777
Interesting! What about the '04? Anyone know if that's the same as the '07?
Unread 03-14-2015, 10:08 AM   #6
LouC
2007 WK
Nope '04 has the spare in the well like '02.
Grand Cherokee geanology:
ZJ series 93-98 tire is bolted upright to the drivers inside quarter panel
WJ series 99-04 it's in the well
WK series 05-10 under the vehicle with the crank it up winch.
Unread 03-15-2015, 12:10 AM   #7
joe989
2008 WK
Oh ok, never had to use it so, wasn't sure... Anyways, you can use an open ended wrench to turn it I suppose.
Unread 03-15-2015, 11:16 AM   #8
LouC
2007 WK
Socket and ratchet wrench can also be used if you have the right size
