Tires and Wheels Advice - JeepForum.com
post #1 of 2 Old 01-14-2013, 06:03 PM Thread Starter
toymachine456
2006 WK
Im looking to buy JK rubicon wheels and tires as a set.
I found a great deal on wheels and tires and Im wondering if the 32 inch BFG MT and JK wheels will fit my 06 WK laredo with an OME HD lift?
I need guidance! Please help!
Thanks!
toymachine456 is offline
post #2 of 2 Old 01-14-2013, 07:11 PM
gamma500
2015 WK
If these are 17" Wrangler rims, you will need to get spacers for the fronts, brake caliper/holder the problem.....only 1/4 " spacer is needed but I believe 6mm is the smallest I've seen on eBay. The rears will clear fine. Tires as far as diameter should fit...if width isn't too excessive. Once again spacers all around will solve that. I researched this question recently for my 05 WK with eBay Rubicon rims (17 x 7.5, 45mm offset)...seems my Rubicon 17" ers fit up front, by about 1.5mm(!!) of clearance from brake caliper holder but brake caliper size, according to Forum consensus, was slightly larger in the 2006+ WK's.
2015 JGC Ltd, 3.6L
gamma500 is offline
bfgoodrich , jeep wk , moabs , mud terrain , ome hd
