Tires clearance for bolt and PW - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Tires clearance for bolt and PW
Savvy Billet LED Tail LightsLight up the holidays with LED lights from JeepHutIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 11-24-2014, 08:21 AM   #1
glettow
2007 WK
So I was able to fit my 255/75/17 on my 2007 wk but it's really close to the bolt. I thought about adding wheel spacers, but I think that might bring the tires closer to pinch weld when the wheels are at full turn. The clearance on the brake calipar is also very close so spacers would also give me some more room there as well. My other option is to leave well enough alone ride with it as is. It just seems really close.
Ideas?
Advice?
1991 XJ -> 2007 WK
glettow is offline   Reply With Quote Quick reply to this message
Unread 11-24-2014, 08:43 AM   #2
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
If it clears the uca bolt/stud then it clears, no matter what.
The p/w on the other hand is hit or miss.
My advice would be to modify your pinch welds.
~Mike~
My Build Thread WK
My Other Build Thread XJ
'01 XJ with some stuff
Sept 2013 Cherokee of the Month
'07 WK with some other stuff
~RED WK CLUB #7~
'11 KK with mostly stock stuff
'06WK our first Jeep with stock stuff - totalled and gone
JeepN4KC is offline   Reply With Quote Quick reply to this message
Unread 11-24-2014, 08:54 AM   #3
DCFD522
Duratrac Wranglers, 255/75/17 w/ 1.5" spacers. Looks awesome, handles great....had to do pinch weld. It's and easy mod. Sledge and a torch for the plastic...didn't even cut the weld, just smashed it flat.
DCFD522 is offline   Reply With Quote Quick reply to this message
Unread 11-24-2014, 09:14 AM   #4
glettow
2007 WK
Thanks for the quick responses so far.
I guess the real question is does it matter by how much it clears the pinch weld and uca bolt/stud, or is it good enough to just barely clear it?
1991 XJ -> 2007 WK
Unread 11-24-2014, 09:50 AM   #5
caulk04
2008 WK
It's not going to get any closer to the bolt. But the PW will rub when the suspension compresses...
Tint, Superchips, SRT intake tube, Gibson catback, catch can. One hardcore DD/kid hauler...yeah.
caulk04 is offline   Reply With Quote Quick reply to this message
Unread 11-24-2014, 03:31 PM   #6
JeepN4KC
JeepN4KC's Avatar
Like I said, if it clears then it clears, no matter what.
~Mike~
My Build Thread WK
~RED WK CLUB #7~
Unread 11-25-2014, 03:30 AM   #7
TangoTango
2008 WK
exactly.
live with minor rubbing or do the pinch weld mod.
Black WK Club #147
TangoTango is offline   Reply With Quote Quick reply to this message
Unread 12-09-2014, 06:37 PM   #8
CavallinoRed
2006 WK
Any problems getting a 255/75/17 tire to fit in the spare tire carrier?
CavallinoRed is offline   Reply With Quote Quick reply to this message
Unread 12-09-2014, 06:50 PM   #9
glettow
2007 WK
Yep, it doesn't fit as is. My spare is still in the trunk area for now. I have the factory hitch receiver so I'll need to trim that for sure.
The other day when I was trying to get the receiver off, one of the bolts would just spin so I'll either have to take the bumper cover off and try again or trim the receiver while it's in place.
I've seen pictures where other WK owners have been successful after the mod so I'm still hopeful.
http://www.jeepforum.com/forum/f67/o...l#post12793004
1991 XJ -> 2007 WK
Unread 12-09-2014, 10:26 PM   #10
glettow
2007 WK
Just to follow up, for anybody who may find this thread later the 255/75/17 BFG Mud Terrain tires on the 2014 rubicon wheels did fit on my 2007 WK 4.7 no rubbing on the UCA bolt (it is very close) and I clear the caliper. I did find there was some very minor rubbing on the front driver side pinch weld. I'll be doing the PW mod later this month when I install my modified OME lift :-)
1991 XJ -> 2007 WK
