Tires - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Tires
The ULTIMATE "Selectable" Locker System! Brough**Flash Weekend Sale** Rockridge4wd.com Only!RIGID LED Light Blowout Sale - All Sizes, All Series, all
Unread 08-06-2015, 11:24 AM   #1
1littleappy
2005 WK
Tires
What is the most aggressive AT tire, without lifting my 2005 WK and keeping the stock wheels?
1littleappy is offline   Reply With Quote Quick reply to this message
Unread 08-06-2015, 11:26 AM   #2
1littleappy
2005 WK
Unread 08-06-2015, 11:52 AM   #3
paroxysym
2007 WK
255/70... its roughly a 31" tire. I currently run hankook dynapro atms in this size at stock height
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline   Reply With Quote Quick reply to this message
Unread 08-06-2015, 01:39 PM   #4
blacknwhite
2005 WK
Paroxysm is not using the stock wheels. You can't follow his advice unless you have his wheels. Try a 245/7o General Grabber AT2. I use those on my otherwise stock Jeep and am quite happy.
img_20150718_121546447.jpg   img_20150419_071110838_hdr.jpg   img_20150315_144339144_hdr.jpg
blacknwhite is offline   Reply With Quote Quick reply to this message
Unread 08-06-2015, 02:16 PM   #5
paroxysym
2007 WK
um... im using a JK 17" which requires a spacer(1/4" to be exact) to clear the caliper, so YES you can use a 255/70 on your stock rims.
check out the wheel/tire combo thread, im not the only one running this size AT stock height. your 245/75s are 31.5x9.7... my 255/70s are 31x10. lol they'll fit fine
OEM+
Unread 08-06-2015, 02:16 PM   #6
Kman09JGC
255/65/17 general grabber at2 with 5100 at 3/4 setting otherwise stock.
09 laredo 28x 4.7 w/QD2 Superchip w/91 perf tune w/ trans app, jet 180 tstat,K&N CAI, bistein 5100 struts and shocks, srt8 front and rear swaybars, 255/65/17 General Grabber at2's.
Black WK Club #107
Kman09JGC is offline   Reply With Quote Quick reply to this message
Unread 08-06-2015, 05:06 PM   #7
ryankokesh
+1 on the AT2s. Love those things.
Untitled by Ryan Kokesh, on Flickr
ryankokesh is offline   Reply With Quote Quick reply to this message
Unread 08-07-2015, 09:11 AM   #8
modernblueWK
I ran 245/70-17 General Grabber AT2's on my wk stock, with a 1/4" strut spacer and with the rc lift. They do not rub at all.
It is a good size for a totally stock wk.
255's will be my next set of at2's. I'm not interested in messing with wheel spacers.
2008 WK 4.7 V8 RC Lift, WK MLL's, G2 Diff Cover, 4XGuard front guard, Steel Armadillo Belly Skid, Superchips, Magnaflow 13742, General Grabber AT2 245/70-17.
Blue WK club #4 Build/Adventure Thread
modernblueWK is offline   Reply With Quote Quick reply to this message
Unread 08-07-2015, 09:12 AM   #9
modernblueWK
Originally Posted by blacknwhite View Post
Paroxysm is not using the stock wheels. You can't follow his advice unless you have his wheels. Try a 245/75 General Grabber AT2. I use those on my otherwise stock Jeep and am quite happy.
Are they 245/70's or 245/75's LT's?
Unread 08-07-2015, 04:26 PM   #10
blacknwhite
2005 WK
245/70's - edited my original post. I don't think a 75 would work without cutting the UCA bolt.
Unread 08-07-2015, 11:34 PM   #11
modernblueWK
I have thought about the 245/75's but the weight penalty would suck. Ive never had a sidewall durability issue with my p series.
