Tire and Wheel Combination - JeepForum.com
post #1 of 21 Old 08-26-2010, 10:48 PM Thread Starter
etp
So, if I go with the Stock rims that come on a 2005 WK Laredo, and get 255/75/17 BFG KM1s, with an OME Lift kit, will I need spacers to clear the tires? Or will I be fine?
etp is offline
post #2 of 21 Old 08-26-2010, 11:43 PM
Jeepin_XJ_101
Yes the bolt is still in the way
"When in doubt... Floor it"
1989 XJ 4.0L I6 -
- NP231 - 4" RC - 33x13.50 MT Claws
*SOLD*
2005 WK 4.7L 3.5" RK, 255/75R17 on Rubi Wheels
1992 YJ 4.0L 5" ProComp on 35x12.50 Trxus MT
Jeepin_XJ_101 is offline
post #3 of 21 Old 08-26-2010, 11:47 PM
rickyantanies
ill bet moabs would look sick on the newer GC
2000 XJ sport 4.5 inch Rough Country Series X lift Cooper Discover M+S 31X10.5 15x8 uniques Dana 30 front Chrysler 8.25 rear Stock gears
Colorado jeep club member #1992
http://www.jeepforum.com/forum/f22/patriot-blue-build-1179435/#post11126000
rickyantanies is offline
post #4 of 21 Old 08-27-2010, 12:09 AM Thread Starter
etp
I want to get a set of Moabs, but thy require spacers for sure. I just want to know if my stock rims need them for my desired tire size.
etp is offline
post #5 of 21 Old 08-27-2010, 12:14 AM
rickyantanies
ya they probably would. If you like your stock rims that much then you can get spidertrax spacers. they are top of the line. Just really expensive
post #6 of 21 Old 08-27-2010, 12:54 PM
criket
2005 WK
You could also go with 245/75 tires. I think some people are running them on here with out any problems with the bolt or the pinch weld. I can't remember who. Search the threads.
2005 | WK | Khaki | 3.7 | QT1 | OME HD Front Struts | Rusty's 2" lift in Rear w/ Monroe load levelers (F150 version) | 265/70 Nitto Terra Grapplers | 17" Moabs | 1.5" wheel spacers | Pinch weld mod Rear fender trim mod | 4xG Matrix w/ reciever hitch | 4xG Belly guard | SOLID Diff cover | Cobra CB radio | 4xG antenna mount | Rola roof
criket is offline
post #7 of 21 Old 08-27-2010, 10:30 PM
lagonwagon
2007 WK
According to the sticky at the top of the thread page, 255/70/17 is the biggest you can run without moding with spacers or trimming the bolt.
lagonwagon is offline
post #8 of 21 Old 08-27-2010, 11:42 PM Thread Starter
etp
If I go with the Spidertrax 1 and 1/4 will I need to trim the bolt or fold the pinch weld?
etp is offline
post #9 of 21 Old 08-28-2010, 12:53 AM
rickyantanies
im not sure. dont know much about spacers just that spidertrax is the best
post #10 of 21 Old 08-28-2010, 01:01 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
If you get 1.25" spacers then yes, you will probably have to do the pinch weld. If you went with .25" spacers then you should be fine.
Omelet is offline
post #11 of 21 Old 08-28-2010, 02:32 AM
lbdyll
2006 WK
I am running 245/75/17 on my 06 with the RC lift. I can almost get my pinky finger between the bolt and the tire with no spacer. With a 255 I am positive you would have to get spacers. Mine do rub on the sway bar and the frame at full lock. Doesn't touch the pinch weld though. There are some pictures on this thread http://www.jeepforum.com/forum/f67/p...5-17-a-981615/
lbdyll is offline
post #12 of 21 Old 08-29-2010, 08:11 PM
Jeepin_XJ_101
Right now I have 255/75R17 on mine stock, and with 1.5" spacers I don't rub at all until I hit a hard bump then you hear it. Without the spacers it would rub really badly. Good thing I finally got my lift kit in
1989 XJ 4.0L I6 -
*SOLD*
post #13 of 21 Old 08-31-2010, 04:44 PM
CraigWK
2005 WK
This question comes up often and makes me wonder what .25" spacer is recommended. Would these be a sufficient fix to the bolt rub issue?
TWO 5 LUG 1/4 SPACER / QUARTER INCH RIM WHEEL SPACER : eBay Motors (item 150419786591 end time Sep-28-10 15:56:41 PDT)
CraigWK is offline
post #14 of 21 Old 09-04-2010, 12:21 AM Thread Starter
etp
So, I am going with the 245/75/17 Wrangler Authority. Do you think it is worth messing with spacers, etc to fix the rubbing? Does the rubbing make the tire wear excessively on that area? Think I would have much rubbing off road? Can you just hammer out that area that it does rum, only at full lock right?
etp is offline
post #15 of 21 Old 09-04-2010, 12:49 AM
Burtman88
1987 YJ Wrangler
I have 255/70/R18 tires on mine and it rubs at little less then full lock and thats about it off road it does great haven't had much rubbing that i know of. i am saving up for spidertrax 1.25 inch spacers so i can pull into the tight parking spaces without tearing the tread off my tires. Your tire is 31.5 inches and mine is 32.1 so mine is a bit bigger so i am guessing rubbing shouldn't be to bad. But check out these things i found online for off roading watch the video. http://www.offroaders.com/directory/...illowtrack.htm
Burtman88 is offline
Front tire to wheel wheel gap... gman1322 ZJ Grand Cherokee Forum 12 07-06-2009 12:31 PM
Question about lift/tire combination sniperdude ZJ Grand Cherokee Forum 0 05-05-2009 04:03 PM
Combination Lift phillyeaglekgd WK Grand Cherokee & XK Commander Forum 2 03-17-2009 12:18 PM
Good Oil/Filter Combination 99wjman ZJ Grand Cherokee Forum 17 08-16-2006 10:46 PM
Exhaust & Intake Combination usernameunavail ZJ Grand Cherokee Forum 7 07-17-2005 09:51 PM
