Tire Wear Issue - JeepForum.com
post #1 of 17 Old 10-24-2012, 01:34 PM Thread Starter
fred99x
2008 WK
Tire Wear Issue
2008 GC CRD completely stock. This past spring, I noticed that the left front tire tread was almost completely wore off along the inside corner of the tire. Figured it must be a aligment problem so I had a wheel alignment done which indicated that there really wasn't much wrong with the alignment. Before taking the GC in for the wheel alignment, I swapped the front and back tire on the drivers side. Now, roughly six months later, the left front tire is doing the same thing, wearing badly on the inside corner tread. Is there anything that could cause this that would not show up on the wheel alignment?
fred99x is offline
post #2 of 17 Old 10-24-2012, 01:50 PM
trax95008
2006 XK Commander
I would have said a faulty tire, but since you swapped it and had the same problem, then it must be alignment. Try a different shop
trax95008 is offline
post #3 of 17 Old 10-24-2012, 01:55 PM
06WKHEMI
2006 WK
Worn suspension
2006 Black wk overland HEMI QDII. OME HD bilstein struts with 58643 monroe load levelers RRO uca, afe cold air intake,hella 500FF behind grille, RC 1.5 wheel spacers s4xc cb antenna mount with 5ft firestik and midland 1001wx CB,265/70-17 falken rockymountain ats, pinch weld mod, door lock mod, Rola basket with 2 Hella 500 FF`s.
06WKHEMI is offline
post #4 of 17 Old 10-24-2012, 02:18 PM
Budasac
2005 WK
Did you actually see the alignment report? Alot of shops don't know how to adjust camber/caster on these trucks. They just "set the toe and let it go". It sounds like an alignment issue.
Budasac is online now
post #5 of 17 Old 10-24-2012, 04:07 PM
modernblueWK
Do you make alot of u-turns?
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #6 of 17 Old 10-24-2012, 04:25 PM
w1pf
Who, me?
w1pf's Avatar
2007 WK
It is either alignment or worn suspension parts, but a good alignment shop will deal with the former and discover the latter.
Unless you make youtube videos for a living, it would be hard to make enough U-turns to make a difference in your tire wear.
2014 WK2 Overland 5.9L
2007 WK Limited 5.7L
And some past Durangos
Red WK #19, Hemi #68.. I think..
Durango Owners Club DOTY 2011
"Must have been that yesterday was the day that I was born"
w1pf is offline
post #7 of 17 Old 10-24-2012, 04:34 PM
modernblueWK
I wear the inner portion of te right front tire on my patrol car pretty quickly. I make alot of u-turns.
Just a thought....
SOLD 2008 WK 4.7 V8
post #8 of 17 Old 10-25-2012, 06:51 AM
yzjwk
2005 WK
Turning causes tire wear on the outside edges of tires , not inside .
Inside tire wear is almost always cause by miss allignment or failing components and as said above , should have been caught by an allignment shop. This is one reason why I would never get an alignment done at a place that primarily sells tires.
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #9 of 17 Old 10-25-2012, 10:07 AM Thread Starter
fred99x
2008 WK
The shop is going to check the alignment again. If they still indicate no alignment issue, then I'll go to a front end shop and see what they say.
fred99x is offline
post #10 of 17 Old 10-26-2012, 06:00 AM
mort1mor
ModernBlueWk those uturns that you're making are those chasing someone who just illegally makes a uturn in turn you cut your blue and reds real quick just to make an illegal uturn then immediately cut your blue and reds off!!!! Just kidding, I just had a similar problem but ended up being a shotty alignment but took it too my regular tire place and they showed like stated above camber, toe/in-out I did get a set of new tires but not rubbing the insides out, peace
mort1mor is offline
post #11 of 17 Old 10-26-2012, 06:37 AM
modernblueWK
Mostly speeders where i live.
SOLD 2008 WK 4.7 V8
post #12 of 17 Old 10-26-2012, 08:07 AM
SSF556
2008 WK
How many miles? I would guarantee that the front shocks are shot.
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #13 of 17 Old 10-26-2012, 09:46 AM
partlowr
2007 WK
I had a cracked/broken spring and it resulted in inner tire wear. I had no idea it was broken until I removed to install my lift kit. It felt normal, drove normal but my spring was in two peices when I removed it.
partlowr is offline
post #14 of 17 Old 10-26-2012, 12:35 PM Thread Starter
fred99x
2008 WK
The jeep has 90,000 km or abouty 55,000 miles. It doesn't ride like the struts are worn and if they were, the wheel alignment should have shown a problem. I took it to a repair shop this morning so I'm waiting to hear back from them. I'll update when I do.
fred99x is offline
post #15 of 17 Old 10-26-2012, 07:53 PM Thread Starter
fred99x
2008 WK
The shop indicates no problems with the front end. Everything seems tight. So now I'll have the alignment shop check the alignment just to verify that the alignment is still good. If the alignment shows good, then I'll have to assume that it may be tire issues or something that's not easy to spot. All this is happening while I'm fixing a vibration when braking issue. Never a dull moment when you own a jeep.
fred99x is offline
tire , wear
