tire size on stock rims with 2" lift and no spacer....the real deal... - Page 3 - JeepForum.com
post #31 of 34 Old 07-10-2013, 06:57 PM
DarthJeep
2005 WK
So I'm confused now...will I need spacers if I put 265/70/17 Hankook DynaPros ATM RF10s on stock Orbitrek rims with an OME HD? I've heard yes and no...
Build Thread -
Black Wk Club 166
DarthJeep is offline
post #32 of 34 Old 07-11-2013, 04:38 PM
EtherealPonx
guys, there is NO wining formula, each possible variation of tire size/tread pattern/ AT/MT / stock rims (are they all the same from 2005 to 2010 import and export models?!) ..... will all result in different dimensions of where the tire sits and clearance from bolt, fender arch etc etc. so ... one size tire with a specific pattern might clear the UCA bolt, and another may not ...
for example, on my '09 GC 5.7 WH Overland, the bolt was vertically above the tire with less than 0.5 an inch of space, so ANY tire bigger would have needed spacers, or better a new set of wheels ...
Here is an alternative to the pinchweld mod, I preferred this 'aftermarket' look
EtherealPonx is offline
post #33 of 34 Old 01-07-2014, 01:30 PM
PDragon
2007 WK
Originally Posted by alexwhite96523 View Post
ok....these are off my blackberry and for that I am sorry....but this is what it looks like....i shot the pinch weld area and i think that you can see the bolt clearance...but if you know anything.....the bottom of the bolt is less than 1cm wide and that's just about how much clearance you've got there!!!
anyway....these are my 245/75/17 bfg mud km2's (ON STOCK RIMS/NO SPACERS!!!!) on my 05 wk limited with the OME HD lift....i freakin love it...
yarrrr...
aw
The WK looks awesome!
Thank you for your input. I was researching the same size, 245/75 R17, and the info was all over the place. I get lots of snow and ice where I live, so 245/75 will be a blessing. Based on your experience I will bite the bullet and get a set of 245/75R17 Discoverer A/T3.
Quick question: Does you mud km2 fit in the spare wheel well?
Thanks once again
2007 WK CRD / QDII /+250,000 kms
GDE Eco tune / OME HD / JBA UCAs
275-75-17 Cooper Discoverer AT3
PDragon is offline
post #34 of 34 Old 01-09-2014, 06:44 PM
JTL13
I installed the OME MD lift , and put 265-70-17 Duratracs on my stock 05 WK LTD rims and had to put an 8mm wheel spacer on because tires were contacting the control arm. Cut the bolt during lift install. I am now shopping for correct offset aftermarket rims because I don't really like the 8mm spacers, and want to go back to hubcentric setup. Anyone know for sure what B/S , offset I need?
05 WK Limited Black Crystal
Hemi
JTL13 is offline
stock 16" rims: baddest tire for it? Astrodokk ZJ Grand Cherokee Forum 23 03-07-2007 08:40 AM
Anyone running stock 16" rims and 4.5" of lift? What size tires do you run? bjl95mustang ZJ Grand Cherokee Forum 5 02-12-2007 12:23 PM
3" lift, 285-75-16 stock limited rims, and 1"wheel spacer. Will it work? bjl95mustang ZJ Grand Cherokee Forum 1 01-26-2006 12:17 PM
2" BB Lift. Largest tire on stock Rims with NO rubbing?? josho66 ZJ Grand Cherokee Forum 15 01-22-2005 06:10 PM
max size tires for stock 02 grand cherokee 16" rims frankieve WJ Grand Cherokee Forum 4 01-20-2004 08:15 PM
