tire size on stock rims with 2" lift and no spacer....the real deal... - Page 2 - JeepForum.com
post #16 of 34 Old 06-28-2010, 05:59 PM
osd
pizza cutters= thin tires
osd is offline
post #17 of 34 Old 11-06-2010, 09:52 PM
Budasac
2005 WK
I just had 265/70/17 mounted on stock rims. Cleared the bolt, no rub on the weld. Slight rub on the frame at full lock. No worries though. By the way, I'm runnin' a two inch lift.
Budasac is online now
post #18 of 34 Old 11-07-2010, 07:47 AM
V6WK
2005 WK
I rock 245/75/17 Hankook RF-10. I Think the truck looks great, and I would rather have a taller tire vs a wider tire. little bit more lift and they are better for winter and the amount of snow we get. I wasnt going to spend the money on spacers to push out stock wheels. If I want wider tires in the future i'll get aftermarket wheels with the correct backspacing.
V6WK is offline
post #19 of 34 Old 11-07-2010, 07:57 AM
AJeepZJ
2006 WK
Well, for what it's worth - I use 255/75/17's but with 1/4'' spacers.
All Gear, No Skill.
AJeepZJ is offline
post #20 of 34 Old 11-07-2010, 10:58 AM
airportdave
Either Flyin' or Jeepin'
airportdave's Avatar
2010 WK
Same tires here- LT 245/75/17, for the same reasons. Gave me just over an inch of extra ground clearance, and doesn't rub, even at full lock. These are 31.5" in diameter, vs. 29.5" on the stock Fortera's I took off. No spacers or lift. I did trim the bolt, but left enough to still get a wrench on it- really didn't need to do it though- I have one fat finger's width between the bolt and the tire. Probably could have gone 255/75/17 in this tire with the stock setup, but wanted to keep good snow and ice traction.
2010 Grand Cherokee Limited Hemi Q-D II, OME MD, 265/70/17 Hankook ATM's, HemiFever Tune
airportdave is offline
post #21 of 34 Old 11-17-2010, 12:12 PM
Budasac
2005 WK
I have to make a correction I have 265/70/17 on stock rims w/ 2" BB lift. No pinch weld, no spacers and NO RUB. I thought they were rubbing a little at full lock, however after driving for a day or two I realized it was my ESP kicking in. Should work properly after getting the computer flashed with new tire size. Until then I have simply been disabling the ESP everytime I start the truck. Also, I did trim " the bolt ", but I didn't have to. There was a bit of clearance but I felt better cutting it. It was not needed though. So 265/70's do fit on the stock rim without any mods. Also, in case any one is curious, they are Firestone Destination AT's. By the way. As far as I can tell, the people who had to fold the pinch weld are not using stock rims. Whether you use spacers or new wheels, as you increase the offset, you also increase the wheel travel. So the further you get from the "bolt", the closer you get to the wheel well (pinch weld) when turning. Just something to think about. Besides, I like the stock rims too. Powder Coated black of course.
post #22 of 34 Old 11-17-2010, 12:35 PM
meep
2008 WK
"Powder Coated black of course."
anyone tried the spray-on bedliner that can be bought at advanced auto?
I've used their rim paint and it worked GREAT and was super-hard (7 days to cure).
Was thinking of doing grill, wheels to match with either coating...
meep is offline
post #23 of 34 Old 11-17-2010, 12:57 PM
AJeepZJ
2006 WK
OMG - that would be incredibly hawt... I can already imagine that looking pretty rugged. I don't think it would look appropriate on a khaki WK like mine. But You've got me considering ideas..
All Gear, No Skill.
AJeepZJ is offline
post #24 of 34 Old 11-18-2010, 07:12 AM
wakeskate420
2006 WK
I run 245/75R17 BFG All-Terrain's with no lift and no rubbing. I had to cut the bolt though, but it looks and rides great! And I'll be throwing the Bilstein's on all the way around as soon as they ship from Germany, so that should add an extra 1/4" of lift, maybe more...
wakeskate420 is offline
post #25 of 34 Old 11-18-2010, 11:13 AM
Devilsmed98
Airportdave is that with no lift?
Also Meep and Carolina check out my post on Plasti-Dip I just made, may be an option for you guys.
~Black WK Club Member #9~
2011 WKII Overland
2007 WK Limited[/COLOR]
1995 YJ Rio Grande
Devilsmed98 is offline
post #26 of 34 Old 11-18-2010, 12:42 PM
airportdave
2010 WK
Yup- no lift, no spacers!
post #27 of 34 Old 11-18-2010, 09:09 PM
Budasac
2005 WK
I would think the texture of the bed liner on wheels would cause mud to stick and cake on. Other then that Bed Liner is pretty tough stuff. I do remember seeing a guy who sprayed his entire F-250 with Rhino Liner. Looked O-K. A little extreme.
post #28 of 34 Old 07-03-2013, 04:14 PM
robswk
2008 WK
So wait, 2 inch ome without spacers or pinch weld on stock fits only 245 at max? I was thinking same thing I like the stock jeep wheels was thinking 255 should be ok but if you have 245 then don't think it would be good idea to get 255...
Bone stock TrailRated 08 4.7l 4x4 wishlist 2inch OME HD LIFT w/ 245/70r17 tires
Black WK Member #42
robswk is offline
post #29 of 34 Old 07-03-2013, 06:48 PM
cr4zyfkr
I can fit 265-70-17 on stock wheels and clear everything with no lift or spacers.
cr4zyfkr is offline
post #30 of 34 Old 07-06-2013, 08:04 AM
robswk
2008 WK
Ok cool, just to double check there wasn't a typo this awesome wk has 245 mud tires on not 265 correct?
Black WK Member #42
robswk is offline
stock 16" rims: baddest tire for it? Astrodokk ZJ Grand Cherokee Forum 23 03-07-2007 08:40 AM
Anyone running stock 16" rims and 4.5" of lift? What size tires do you run? bjl95mustang ZJ Grand Cherokee Forum 5 02-12-2007 12:23 PM
3" lift, 285-75-16 stock limited rims, and 1"wheel spacer. Will it work? bjl95mustang ZJ Grand Cherokee Forum 1 01-26-2006 12:17 PM
2" BB Lift. Largest tire on stock Rims with NO rubbing?? josho66 ZJ Grand Cherokee Forum 15 01-22-2005 06:10 PM
max size tires for stock 02 grand cherokee 16" rims frankieve WJ Grand Cherokee Forum 4 01-20-2004 08:15 PM
