tire size on stock rims with 2" lift and no spacer....the real deal... - JeepForum.com
post #1 of 34 Old 06-17-2010, 12:46 PM Thread Starter
alexwhite96523
2005 WK
OK...so after reading the faq about tire size...and getting completely inconsistent data on the forum...I decided to go out and try something on my own...
the faq says the largest tire you can run is a 265/70...they should also have mentioned the pinch weld mod/bolt cut/backspacing issues....so i devalue that answer....
IMO if you've just got done buying a lift and tires....the last thing you want to do is pay 4-500 more for new rims....AND i LIKE my stock rims...I think they look sharp.....
So after some measuring and comparison from the stock tires I had on there (GY Wrangler HP 235/65/R17s) to what I wanted to try to mount (BFG Mud Terrain KM2 245/75/R17s) I took the plunge and ordered the tires...
Many people told me that these tires WOULD contact "the bolt" and I would have to trim...many people were WRONG...there is about 1cm of space between the tire and the bolt...you can stick the tip of your finger between the tire and the bolt....without trimming....
Many people also told me I would have to do the "pinch weld mod" this was also incorrect information....at full lock there is no contact with the fender in front of the pinch weld....at all...
HOWEVER...there is MINIMAL contact with what i guess is the unibody and the tire at FULL lock....when I say minimal I mean minimal...I believe that running a minimal spacer of <.5" would correct this and enable you to hold the wheel at full lock with zero contact between the tire and anything other than the dirt on the ground....
I know that I owe you guys pictures...I will make sure I get them posted...the overall point I am trying to make is that I mounted a 31.7" diameter tire on a stock rim and I wont be hacking and chopping my jeep to death...
I know it's not as WIDE as some of you guys like...but i think it's a FANTASTIC compromise for those of you that want to run stock rims....
alexwhite96523 is offline
post #2 of 34 Old 06-17-2010, 06:02 PM
theSovereign
2007 WK
Thanks for sharing that info.
I just received my 245/75/17 BFG All-Terrains today and am still waiting for my OME kit. I'll be using the stock wheels as well, so it's nice to see your post validating minimal install issues for this configuration. =)
theSovereign is offline
post #3 of 34 Old 06-18-2010, 05:25 AM
Snow4Lif3
2005 WK
You are the second one I know who put 245/75R17. I don't know why there is no more people using it. I'll probably go why this size of tire... but I wonder if its will look too narrow. I can't have them test fitted here. That would be nice if you can post some photo of you jeep with those tire on, especially the front and the back ! Thank you !
Snow4Lif3 is offline
post #4 of 34 Old 06-18-2010, 05:32 AM
LJS8510
LJS8510's Avatar
2015 WK
That is great it worked out for you.
Have you taken it off road yet?
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #5 of 34 Old 06-18-2010, 06:55 AM
Dreezy
1990 FSJ Wagoneer
I have 245/75/17 bridgestone at's for my winter tires on my stock wheels. I use them for winter duties. I have kmc spy's with dura trac in 265/70/17's for my summer/offroad setup without folding the pinch weld. They do rub a little however. Both setups do. I also have moog upper ball joints.
Dreezy is offline
post #6 of 34 Old 06-22-2010, 12:19 PM Thread Starter
alexwhite96523
2005 WK
I'll get some pictures up...I dont think they are too skinny....but I didn't want my tires to poke out of the wheel wells....
post #7 of 34 Old 06-22-2010, 12:37 PM
harascho
2005 WK
245/75r17
Thx a lot alexwhite96523.
This info came just in time. I fitted a 2" OME suspension and I also want to keep my stock wheels. I had them sandblasted and powdercoated in flat black.
The tire of my choice is the 245/75R17 Goodyear Wrangler silent armor 'cause this fits my needs of an All Terrain tire which is very capable in snow. Also the speedindex is higher than with the other AT tires.
Harald
harascho is offline
post #8 of 34 Old 06-22-2010, 01:22 PM
theSovereign
2007 WK
Same here, didn't want the tires sticking out of the wheel wells and throwing excess debris/dirt/rocks/mud/snow at objects behind the Jeep, as well as have better snow performance of a narrower tire.
Looking forward to the pics. =)
post #9 of 34 Old 06-22-2010, 07:02 PM
Snow4Lif3
2005 WK
Thank you !
IM waiting for your pics... It will sure help me make my decision... it will be 245/75R17 (E rated) or 265/70R17 (C rated) BFG A/T KO.
post #10 of 34 Old 06-22-2010, 07:18 PM
osd
285 70 17 going on my truck with the ome lift
hey man whatever works for you. i was gonna do 265 but i found a sick price for a set of 285 tires. im really curious about seeing the wheels flat black.
osd is offline
post #11 of 34 Old 06-26-2010, 07:27 PM Thread Starter
alexwhite96523
2005 WK
ok....these are off my blackberry and for that I am sorry....but this is what it looks like....i shot the pinch weld area and i think that you can see the bolt clearance...but if you know anything.....the bottom of the bolt is less than 1cm wide and that's just about how much clearance you've got there!!!
anyway....these are my 245/75/17 bfg mud km2's (ON STOCK RIMS/NO SPACERS!!!!) on my 05 wk limited with the OME HD lift....i freakin love it...
yarrrr...
aw
post #12 of 34 Old 06-27-2010, 08:34 AM
theSovereign
2007 WK
Thanks for posting photos, the Jeep looks great! I like the backdrop too... =)
Do you have a photo from the rear?
post #13 of 34 Old 06-28-2010, 04:56 AM
LJS8510
LJS8510's Avatar
2015 WK
Looks great!
LJS8510 is offline
post #14 of 34 Old 06-28-2010, 11:58 AM
BonesWK
2006 WK
looks good, but a little too much like pizza cutters for me... but like you said YOU love it. which is what matters.
let us know how them KM2's preform!
Ryan
2006 Black WK Limited 4.7 4x4 QD II SOLD
Current - 2008.5 Mazdaspeed 3
If you want to achieve greatness, stop asking for permission
BonesWK is offline
post #15 of 34 Old 06-28-2010, 12:43 PM Thread Starter
alexwhite96523
2005 WK
pizza cutters?
i don get it
stock 16" rims: baddest tire for it? Astrodokk ZJ Grand Cherokee Forum 23 03-07-2007 07:40 AM
Anyone running stock 16" rims and 4.5" of lift? What size tires do you run? bjl95mustang ZJ Grand Cherokee Forum 5 02-12-2007 11:23 AM
3" lift, 285-75-16 stock limited rims, and 1"wheel spacer. Will it work? bjl95mustang ZJ Grand Cherokee Forum 1 01-26-2006 11:17 AM
2" BB Lift. Largest tire on stock Rims with NO rubbing?? josho66 ZJ Grand Cherokee Forum 15 01-22-2005 05:10 PM
max size tires for stock 02 grand cherokee 16" rims frankieve WJ Grand Cherokee Forum 4 01-20-2004 07:15 PM
