tire size - JeepForum.com
post #1 of 4 Old 02-15-2014, 12:18 AM Thread Starter
rmcgee89
2005 WK
tire size
Ok I got a 05 wk with a 2" rough country lift. I also have 2" wheel spacers. I need to know the largest size tire I can fit comfortably without rubbing while turning or anything. I got black rock 17x8 rims. Please help me out here!!
rmcgee89 is offline
post #2 of 4 Old 02-15-2014, 03:34 AM
imann
2006 WK
Before anyone yells at you I'll help you and direct you to the numerous stickies,threads and posts about this....just literally go look at tire/wheel combo threads. good luck......also depends on if you've done the pinch weld and rear fender mod.
06WK slvr#107-hemi-QDII-3.5 Mopar-bilsteins-JBA frnt discos-275/70r17 BFG KM2 MTs-BT cc-
Airraid CAI-Magnaflow exh-super chip prgmr-9k MM winch in custom frnt bumper wth D-rng's
4x grd frnt/rear skids & rear sliders w/D-rng's-BT shrty ant-stillen crs drlld x4-pinch weld mod
imann is offline
post #3 of 4 Old 02-15-2014, 05:19 AM
Jeepforthewin
2010 JK Wrangler
As Imann said use the stickies or search function. They are your best friend on this site. Now since this is your first post it is understandable so we can't get mad at you for that. Back to the question. With the 2" lift most folks end up going with a size 265/70/17 tire. What is the backspacing on your wheels? You may have no need to install spacers and 2" spacers are pretty big so the wheel will stick out pretty far.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #4 of 4 Old 02-15-2014, 12:22 PM
Mainsail
2005 WK
2" spacers?
I think that will push the wheels outside the wheel-wells, and might look ridiculous. I think most of the people in here that run spacers are using 1½"
Poor grammar is something up with which I shall not put.
Mainsail is offline
