Tire rubbing HELP! - Page 5 - JeepForum.com
post #61 of 77 Old 10-24-2013, 06:24 PM
chayden088
That's probably what it is during tight turns with any speed. Lemme guess, the sound is predominantly from the front outside wheel in turns?
I'm not positive if it comes from mostly the outside because it's load enough where I can't tell. Although this could be wrong but it might happen a little more while turning right. Then again this could because that would make me closer to the outside wheel therefore I can hear it more.
chayden088 is offline
post #62 of 77 Old 10-24-2013, 06:24 PM Thread Starter
B_Baity10
Originally Posted by JeepN4KC
I stand by my statement in my previous post: "......you clearly have no idea what you're talking about."
Do you even drive a jeep?
B_Baity10 is offline
post #63 of 77 Old 10-24-2013, 06:27 PM
Jeepforthewin
2010 JK Wrangler
Originally Posted by B_Baity10
If you want the most tire clearance cut it off and re weld it. There is not "jeep law" saying you have to do things a certain way. It's better to do things that work best for you then follow some one else
Honestly you are the first person I have ever seen on here cut it off. We follow some one else because it works well and is SAFE! Cutting of the pinch weld ruins the integrity. If it wasn't necessary then it wouldn't be there right? There is no need to be rude to other members here (especially ones with a lot of experience in not only WK's but also other Jeeps) because we are trying to help you be safe. We are a community of Jeep loving people and we take care of our people. So like I stated we are saying things to you for safety purposes. Not to disrespect you or bash on you.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #64 of 77 Old 10-24-2013, 06:29 PM
Jeepforthewin
2010 JK Wrangler
Funny thing is he owns more than one Jeep....
post #65 of 77 Old 10-24-2013, 06:29 PM Thread Starter
B_Baity10
Look, It worked, if it messes up oh well I'll get it fixed no big deal
post #66 of 77 Old 10-24-2013, 06:31 PM Thread Starter
B_Baity10
Oh really? Bravo
post #67 of 77 Old 10-24-2013, 06:33 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Well it is common for WK folks with a lift to experience the traction control/btc (brake throttle control) kick in during tight turns especially with any speed. The computer senses the outside tire's excessive spin, relative to the inside tire, as just that - tire spin. So the btc kicks in on the outside wheel. This sounds like abs and a screeching rattle from the backing plate of the wheel hub/rotor assembly.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #68 of 77 Old 10-24-2013, 07:19 PM
chayden088
post #69 of 77 Old 10-24-2013, 08:11 PM
Tcolin2351
2006 WK
Oh really? Bravo
Dude, don't get your panties in a bunch when we all tried to help you. There's some guys on here that you can learn a thing or two from and your nemesis is one of them.
Learn a thing or two and make some friends on here like i did.
06 LJ - Stock for now
Tcolin2351 is offline
post #70 of 77 Old 10-24-2013, 08:59 PM
ttusqrl
2005 WK
Chayden -- The easy test is to hold down your ESP button and turn traction control off. I give it a 50/50 chance of going away without seeing your Jeep. Whatever you do, don't listen to Baity, even if it doesn't go away with the TC turned off.
2005 WK 5.7 ORT | Mod SL (OME struts & 990s) | JBA UCAs & Discos | Saguaro Front Bumper | Warn Zeon 10s | 285/70/17 BFG TA KO | AIRAID CAI | Gibson 3" Exhaust | DiabloSport Intune | JL Stealthbox
ttusqrl is offline
post #71 of 77 Old 10-24-2013, 09:02 PM
chayden088
What and where is the ESP button? Thanks for the help and quick responses to everyone as well.
post #72 of 77 Old 10-24-2013, 09:18 PM
Jeepforthewin
2010 JK Wrangler
It's located below your HVAC buttons
post #73 of 77 Old 10-25-2013, 05:44 AM
DarthJeep
2005 WK
Try this...I did and it helped a little. Take some white chalk dust and lightly cover the places you think it rubs (for me the pinch weld area) and just drive in a parking lot slowly (DRY OUT). You will see the tire rub marks.
Build Thread -
Black Wk Club 166
DarthJeep is offline
post #74 of 77 Old 10-25-2013, 01:42 PM
816jared
2005 WK
is it possible that it's the bolt from one of the UCA's?
2005 WK // 4.7L // OME HD // lots more
816jared is offline
post #75 of 77 Old 10-25-2013, 07:40 PM
JeepN4KC
JeepN4KC's Avatar
If it was it wouldn't be intermittent. The relationship between the tire shoulder lugs and that bolt is constant. As the wheel/tire moves up/down in travel so does the spindle/ball joint/nut/control arm. As well, the nut is more or less in the center of the wheel so that plane never changes.
In other words, the tire either clears the bolt or it doesn't - regardless of any factor other than fitment.
~Mike~
WK
XJ
JeepN4KC is offline
