Tire rubbing HELP! - Page 4 - JeepForum.com
post #46 of 77 Old 10-24-2013, 08:10 AM Thread Starter
B_Baity10
Originally Posted by Tcolin2351
Splashing slush with salt in it can do damage too over time. Good idea getting it welded. The liner looks good!
Was your liner difficult to install?
B_Baity10 is offline
post #47 of 77 Old 10-24-2013, 08:14 AM
Tcolin2351
2006 WK
I haven't done it yet. Been working a lot lately. Hopefully this weekend
06 LJ - Stock for now
Tcolin2351 is offline
post #48 of 77 Old 10-24-2013, 09:02 AM
ttusqrl
2005 WK
Originally Posted by B_Baity10 View Post
Sal isn't going to touch it with the liner over it, I'm getting it welded anyways just in case.
Good call. I honestly wouldn't drive it in the meantime if I were you. As mentioned earlier, the pinch welds are crucial to the integrity of the unibody at all four corners. I would hate to see what would happen to a passenger (or the Jeep for that matter) if you got in an accident with a compromised corner on the unibody. The pinch welds don't look like much, but they are there for a purpose.
Don't forget to prime it and put some protectant over it after the welding -- this is still necessary on bare metal.
2005 WK 5.7 ORT | Mod SL (OME struts & 990s) | JBA UCAs & Discos | Saguaro Front Bumper | Warn Zeon 10s | 285/70/17 BFG TA KO | AIRAID CAI | Gibson 3" Exhaust | DiabloSport Intune | JL Stealthbox
ttusqrl is offline
post #49 of 77 Old 10-24-2013, 09:55 AM
Jeepforthewin
2010 JK Wrangler
Glad to hear you are rewelding it! It may be a DD with minimal off road use but a pot hole can do some damage also.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #50 of 77 Old 10-24-2013, 06:36 PM
chayden088
Hey guys I have a quick question. I have the RC 2 inch lift and 1.5 inch wheel spacers with 265/70/17 wrangler dura tracks. I had a good amount of rubbing at slow parking speeds and also coming out of stop signs with tight turns at faster speeds. My dad who is a mechanic did the pinch weld mod and all rubbing is gone at slow speeds. But at those faster tight turns there is still a lot of rubbing. It makes an awful sound too I cringe every time I here it because at first we cut the plastic thinking that would help but after it just rubbed on the metal and sounds much worse. It almost sounds like abs breaks or traction control coming on. So my question is, is that definitely my tires or could it be something else? Why would it not rub at full lock while parking?
chayden088 is offline
post #51 of 77 Old 10-24-2013, 06:39 PM
Jeepforthewin
2010 JK Wrangler
You said your dad performed the PW mod but they tire is rubbing on the metal? If shouldn't run at all after the mod. If I misread and you did perform the mod fully then it sounds like something else is wrong. If the tire doesn't contact during full lock it shouldn't when turning.
[EDIT]
Do you feel any binding or anything when turning faster?
post #52 of 77 Old 10-24-2013, 06:42 PM Thread Starter
B_Baity10
If you don't cut the metal with the plastic then obviously you're going to rub.
post #53 of 77 Old 10-24-2013, 06:50 PM
chayden088
[EDIT]
Yeah the metal is flush to the fender well. I personally think that it may be both because I get the feeling of binding but I also can hear the tread rubbing. Also if this makes a difference, when I step on the pedal hard from a stop trying to make a tight turn sometimes my jeep doesn't want to go anywhere. Like there is no throttle response and rpms don't even move. Then when it finally goes I get the loud rubbing. If it were to be some kind of abs, traction control or binding problem would it still happen if I turn my traction control off because I've tried that and it still happens?
post #54 of 77 Old 10-24-2013, 06:56 PM Thread Starter
B_Baity10
Just cut the whole pinch weld off like I did and get it welded back together. I mean I have the exact same lift and spacers as you and I'm running 265/70/17 general grabber at2's with after market wheels and I have no rubbing
post #55 of 77 Old 10-24-2013, 06:59 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
That's probably what it is during tight turns with any speed. Lemme guess, the sound is predominantly from the front outside wheel in turns?
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is online now
post #56 of 77 Old 10-24-2013, 07:02 PM
JeepN4KC
JeepN4KC's Avatar
NO - don't do this. It's a waste of time and not necessary.
All due respect, you really have no business recommending folks do that because you clearly have no idea what you're talking about.
~Mike~
WK
XJ
post #57 of 77 Old 10-24-2013, 07:16 PM
Jeepforthewin
2010 JK Wrangler
There is a reason we all do the Pinch Weld mod a certain way. It's not because it's the easiest way or the simplest, it's because it works and is also safe. Cutting it off and rewelding does work but it is more work than necessary and I personally would recommend everyone do it the way everyone else has. Especially someone who is new to the forums and is learning. No disrespect intended. Sorry if it was rude in anyway.
post #58 of 77 Old 10-24-2013, 07:18 PM Thread Starter
B_Baity10
Originally Posted by JeepN4KC
NO - don't do this. It's a waste of time and not necessary. All due respect, you really have no business recommending folks do that because you clearly have no idea what you're talking about.
Do you even drive a jeep?
post #59 of 77 Old 10-24-2013, 07:20 PM Thread Starter
B_Baity10
If you want the most tire clearance cut it off and re weld it. There is not "jeep law" saying you have to do things a certain way. It's better to do things that work best for you then follow some one else
post #60 of 77 Old 10-24-2013, 07:23 PM
JeepN4KC
JeepN4KC's Avatar
I stand by my statement in my previous post:
"......you clearly have no idea what you're talking about."
~Mike~
WK
XJ
