Tire rubbing HELP! - JeepForum.com
post #1 of 77 Old 10-22-2013, 03:51 PM Thread Starter
B_Baity10
Tire rubbing HELP!
My tires are rubbing against the plastic piece under my fenders, any ideas how to prevent this?
B_Baity10 is offline
post #2 of 77 Old 10-22-2013, 03:58 PM
tjkj2002
2002 KJ Liberty
tjkj2002 is offline
post #3 of 77 Old 10-22-2013, 04:06 PM Thread Starter
B_Baity10
I was thinking about sanding them down lol
post #4 of 77 Old 10-22-2013, 05:30 PM
Jeepforthewin
2010 JK Wrangler
Sanding won't do you any good! You will need to do the Pinch Weld mod and cut the weld behind the plastic peice then hammer it to the side and then melt the plastic and form it to the bent over weld.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #5 of 77 Old 10-22-2013, 07:27 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Originally Posted by tjkj2002 View Post
^^^ Meh..........this works better:
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #6 of 77 Old 10-22-2013, 07:33 PM
Jeepforthewin
2010 JK Wrangler
Oh, and also this BFH
post #7 of 77 Old 10-22-2013, 08:17 PM
BAH101
2008 WK
What are you going to do with that...scare it over lol
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #8 of 77 Old 10-22-2013, 08:23 PM
Jeepforthewin
2010 JK Wrangler
With that one yes haha but if it was a real hammer that size it would work great!
post #9 of 77 Old 10-23-2013, 04:47 AM Thread Starter
B_Baity10
I just don't understand why it's rubbing? The RC 2" lift prefers you to run a 265/70/17 and that's what I have on it
post #10 of 77 Old 10-23-2013, 05:48 AM
Jeepforthewin
2010 JK Wrangler
It happens to eveyone. The PW mod is very easy to do and will gain you a lot more clearance
post #11 of 77 Old 10-23-2013, 05:50 AM Thread Starter
B_Baity10
So just cut the metal behind the plastic piece and then either mold the plastic or beat it back with a hammer?
post #12 of 77 Old 10-23-2013, 05:52 AM
Tcolin2351
2006 WK
I did the OME HD with 265/70's and had to do the PW as well. It's really simple, i did it in an hour or so and had no rubbing issues since then
06 LJ - Stock for now
Tcolin2351 is offline
post #13 of 77 Old 10-23-2013, 05:57 AM
Jeepforthewin
2010 JK Wrangler
No you make horizontal cuts about every inch or so along the weld then beat the over with a hammer untill they they are flat against the fender well and then you put the liner back on and hear the plastic up with a heat gun and massage it towards the fender well to flatten it. Go to the DIY sticky up top and scroll down. You will see a walkthrough of the mod and it's very detailed. Great write up, it's the one I used when doing mine.
post #14 of 77 Old 10-23-2013, 06:08 AM Thread Starter
B_Baity10
Ok thanks for the help!
post #15 of 77 Old 10-23-2013, 06:13 AM Thread Starter
B_Baity10
How do you get to the stickies via the mobile app?
