Tire rotation (5 wheels) - JeepForum.com
post #1 of 5 Old 02-28-2013, 07:52 AM Thread Starter
norwaywj
2006 XK Commander
I'm putting on some BFG MT's on my Jeep Commander With QDII.
I have 5 equal tires and rims. What kind of rotation pattern should I use ?
norwaywj is offline
post #2 of 5 Old 02-28-2013, 07:56 AM
misfit77
If you plan on keeping the same tire size..I would never put the spare into rotation. I would just front back and back to front.
I had a 2006 GC, but did not keep the turd long enough to rotate the tires.
Users manual would be best source.
I am sure there is some safety rule stating how long a tire can be exposed to the elements before it should be thrown away.
misfit77 is offline
post #3 of 5 Old 02-28-2013, 08:01 AM
sk1er18
2007 XK Commander
Rearward cross with the drivers front going to the spare and the spare going to the passengers rear spot.
-Matt
sk1er18 is offline
post #4 of 5 Old 02-28-2013, 08:05 AM
trax95008
2006 XK Commander
Rotating the spare in is NOT a bad idea at all. Especially considering how sensitive our diffs are to tire diameter. If your tires were worn, and you got a flat, using a spare with full tread could actually do some harm. Rotation pattern is different for 4wheel drive than 2wheel. I don't have the pattern memorized, whenever I need to know it, I google it. You should check there.
trax95008 is offline
post #5 of 5 Old 02-28-2013, 08:27 AM
JRLT
2010 WK
Found this here: http://www.tirerack.com/tires/tirete...jsp?techid=43&
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
